- Thank you received: 595
Schaublin 125-CNC retrofit.
- RotarySMP
2 years 8 months ago - 2 years 8 months ago #294269
by RotarySMP
Replied by RotarySMP on topic Schaublin 125-CNC retrofit.
Thanks guys. The brackets around the variables works. I didn't get much time on the lathe today, so I didn't have a chance to scale 100x and back yet.
I can see that for this part, I really need to find a couple of quiet days and learn how to do this in a Comp. Rod generously wrote me a draft comp for the variator control back in August, but I still haven't found the time to install it and build on it.
forum.linuxcnc.org/26-turning/41498-scha...fit?start=540#277475
Mark
Mark
Last edit: 2 years 8 months ago by RotarySMP.
- Thank you received: 4153
2 years 8 months ago #294323
Replied by rodw on topic Schaublin 125-CNC retrofit.
I could not even remember writing that. It will be interesting to see how well it works when you get to it!
- RotarySMP
2 years 4 months ago #302763
by RotarySMP
The following user(s) said Thank You: tommylight, spumco, smc.collins
- Thank you received: 2177
2 years 4 months ago #302765
Replied by Aciera on topic Schaublin 125-CNC retrofit.
Maybe the same problem described here:
forum.linuxcnc.org/20-g-code/44739-g96-issue
- spumco
- Thank you received: 905
2 years 4 months ago #302779
by spumco
Do you need a parting tool and inserted threading bar donation?
If you just want a recommendation, I've been pretty happy with the MGMN double-ended holders & inserts (2mm & 3mm), as well as the lay-down insert threading bars.
For small threads P Horn ($$) and Micro 100 ($) solid carbide are nice.
Now get the tool changer going!
Replied by spumco on topic Schaublin 125-CNC retrofit.
I used the Schaublin...
- RotarySMP
2 years 4 months ago #302798
by RotarySMP
Thanks for the offer. I just received a care package with three parting tool holders in it, so I should be good for the next two attempted parting moves
Yeah, I know, but I am on a welding trip at the moment.
The following user(s) said Thank You: spumco, smc.collins
Moderators: piasdom
Time to create page: 0.738 seconds
