Mesa 7I44-7I70/7I71
- SRT
11 Dec 2011 16:11 #15554
by SRT
Mesa 7I44-7I70/7I71 was created by SRT
Are the Mesa 7I44-7I70 and 7I71 cards supported yet on the latest V2.5? This is the set-up I will be installing through a 5I23 with a 7I79 for the resolvers.
I ran across this from one of my older posts.
(Note that the support for the 7i70 / 7i76 etc is not in there yet, but I just need to press a button to make it happen)
- Thank you received: 5252
11 Dec 2011 16:20 #15555
Replied by PCW on topic Re:Mesa 7I44-7I70/7I71
Yes all the 7I7X SSerial cards are supported in the latest 2.5
7I49 and 7I44 on 5I23 will require RMSVSS6_8.BIT configuration:
RM = Resolver Module
SV = Servo for PWMs
SS = SmartSerial
SV = Servo for PWMs
SS = SmartSerial
- SRT
12 Dec 2011 00:56 #15571
by SRT
Replied by SRT on topic Re:Mesa 7I44-7I70/7I71
Can you tell me where to find this firmware? I have been in the pncconf and it is not listed as an option. I looked on the Mesa site and did not see it there either.
SV = Servo for PWMs
SS = SmartSerial
SV = Servo for PWMs
SS = SmartSerial
- SRT
12 Dec 2011 01:04 #15572
by SRT
In an effort to answer my own question. Do I have to have the boards connected while using pnc? Maybe that is why it is not an option to me?
12 Dec 2011 02:51 - 12 Dec 2011 03:00 #15575
freeby.mesanet.com/rmsvss6_8.bit is the 5I23 bitfile
I dont have a .pin file ATM but its setup for:
7I49 six channel resolver /analog servo interface on P2
7I52S six channel encoder plus six PWM/DIR channels on P3
7I44 Eight RS-422 interface on P4 (FPGA has eight channel SSerial interface)
I think this will be tough for pncconf to support
Last edit: 12 Dec 2011 03:00 by PCW. Reason: link
- Thank you received: 2160
12 Dec 2011 03:41 - 12 Dec 2011 03:55 #15579
Replied by cmorley on topic Re:Mesa 7I44-7I70/7I71
at the present pncconf only supports 1 port of max 4 channels of sserial ( the other four are just not configurable in pncconf but you could do it manually in HAL)
the 7i70/7i71 are not supported yet. I need at print out of the HAL pins before I can. The 7i64 is supported (mode 0 only)
the resolver daughther board is supported in pncconf but i've not tested the HAL code to see if it is right.
you do not have to have the boards connected for pncconf to work but you need the XML file.
Peter does not supply these. but if he supplies the pin file I can hand make one if you would like to experiment.
Or just build the config by hand
Last edit: 12 Dec 2011 03:55 by cmorley.
- SRT
12 Dec 2011 14:42 #15588
by SRT
I am a little confused. Are you saying that if I had the 7I52 it would go to P3?
I have purchased the 7I44 resolver /analog servo interfacs and the 7I44 RS-422 Interface along with the 7i70 and 7i71 boards.
12 Dec 2011 16:08 #15590
Yes if you had a 7I52S it would go to P3
Since you don't have 7I52S you leave P3
unconnected or use it for GPIO or
GPIO daughtercards like the 7I37
- SRT
12 Dec 2011 19:44 #15603
by SRT
I kind of figured I would be making it by hand. I was hoping for the best, I am very green to Linux and EMC2, I hope my questions are not way out of left field. Just trying to learn and apply in very small steps.
- SRT
18 Dec 2011 22:15 #15819
by SRT
I keep getting an error when i try and start EMC2 with my config 10CC. I created it in pnc but edited the correct firmware into it. It looks like it can not find the firmware and that is why it is showing the error. Any help would be appreciated. Here is the error report, thanks.
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/lib/tcltk/emc2
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.5.0-pre2-422-gecd2cf4
Machine configuration directory is '/home/srt/emc2/configs/10CC'
Machine configuration file is '10CC.ini'
INIFILE=/home/srt/emc2/configs/10CC/10CC.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Shutting down and cleaning up EMC2...
Running HAL shutdown script
Killing task emcsvr, PID=3975
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/emc2/hm2_pci.ko': -1 Unknown symbol in module
10CC.hal:9: exit value: 1
10CC.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
3975
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 4426.016181] I-pipe: Domain RTAI registered.
[ 4426.016195] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 4426.016200] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 4426.016278] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4426.016283] PIPELINE layers:
[ 4426.016288] fc898e20 9ac15d93 RTAI 200
[ 4426.016293] c085cb20 0 Linux 100
[ 4426.062172] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4426.062483] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 4426.062495] RTAI[sched]: hard timer type/freq = APIC/12499628(Hz); default timing: periodic; linear timed lists.
[ 4426.062503] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1800080000 hz.
[ 4426.062508] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4426.062633] RTAI[usi]: enabled.
[ 4426.150913] RTAI[math]: loaded.
[ 4426.278673] hm2: loading Mesa HostMot2 driver version 0.15
[ 4426.284681] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4426.284955] hm2_pci 0000:03:00.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[ 4426.284964] hm2_pci: discovered 5i23 at 0000:03:00.0
[ 4426.285312] hm2_5i23.0: firmware: requesting hm2/5i23/rmsvss6_8.BIT
[ 4426.288238] hm2/hm2_5i23.0: firmware hm2/5i23/rmsvss6_8.BIT not found
[ 4426.288248] hm2/hm2_5i23.0: install the package containing the firmware.
[ 4426.288256] hm2_5i23.0: board fails HM2 registration
[ 4426.288288] hm2_pci 0000:03:00.0: PCI INT A disabled
[ 4426.288303] hm2_pci: probe of 0000:03:00.0 failed with error -2
[ 4426.945329] hm2: unloading
[ 4427.022311] RTAI[math]: unloaded.
[ 4427.057251] SCHED releases registered named ALIEN RTGLBH
[ 4427.088496] RTAI[malloc]: unloaded.
[ 4427.188046] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4427.193913] I-pipe: Domain RTAI unregistered.
[ 4427.194002] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Cleanup done
3975
Time to create page: 0.098 seconds
