Mesa 7I44-7I70/7I71
26 Jan 2012 09:33 #17150 by Nick
Replied by Nick on topic Re:Mesa 7I44-7I70/7I71
Hi!
Is there any firmware for 5i20 that supports working with resolvers trough 7i49. I saw a lint to one in this thread but it's written that that firmware is only for 5i23.
26 Jan 2012 12:34 #17154 by andypugh
Replied by andypugh on topic Re:Mesa 7I44-7I70/7I71
Mesa almost certainly have one, but currently there isn't one as part of the default set supplied with LinuxCNC.
26 Jan 2012 13:06 #17155 by Nick
And unfortunately there's no such firmware at mesanet.com
26 Jan 2012 14:48 #17157 by andypugh
Maybe not in the software pack, but I suspect that they do have one.
In principle you can make your own.
26 Jan 2012 15:42 #17164 by PCW
Replied by PCW on topic Re:Mesa 7I44-7I70/7I71
Unfortunately the 7I49 support firmware will not fit in the 5I20s Spartan 2 FPGA
(and I tried pretty hard)
The current firmware is big because its pretty brute-force (32 bit DSP, table driven waveform generator, Sine lookup table, synchronous DAQ system with double buffered dual ported RAM, 6 channel hardware position integrator etc etc)
It also uses lots of BlockRAMs for code/data/tables/waveform/DAQ, which are in short supply on the 5I20s FPGA. Whats worse, the DSP uses a 16X16 --> 32 hardware multiplier which is free on Spartan 3 and > but needs to be built with logic on the Spartan2
I think the best I ever got trying to make it fit in a 5I20 was 140% of resources :-(
It will not fit in the 7I43-200 either.
Its entirely possible for a smart FPGA jockey to make a more elegant design that fits but its beyond my capabilities at least without months of time to spend on it.
27 Jan 2012 19:46 #17201 by Nick
Thanks a lot for detailed answer!!!
Can you advise me about Mesa 7i43+7i39, we've found one firmware, but I'm not sure it works properly.
After doing
halcmd loadrt hm2_7i43 CONFIG="firmware=hm2/7i43-4/SVST4_4_7I39.BIT num_encoders=3 num_3pwmgens=3 num_stepgens=2"
or
halcmd loadrt hm2_7i43 CONFIG="firmware=hm2/7i43-4/SVST4_4_7I39.BIT num_encoders=3 num_pwmgens=3 num_stepgens=2"
we got
RTAPI: ERROR: could not open shared memory (errno=2)
and segmentation error.
As for the firmware we've got it from here comments.gmane.org/gmane.linux.distributions.emc.user/29630
27 Jan 2012 19:56 - 27 Jan 2012 20:05 #17202 by PCW
Is this LinuxCNC 2.5?
I dont think the three phase PWMgen is supported by earlier versions
dmesg | tail -100 after EMC bails will probably show more diagnostic info
Last edit: 27 Jan 2012 20:05 by PCW. Reason: command line error
27 Jan 2012 21:08 #17204 by Nick
Yep, it's 2.5 moreover we've tried 2.6. With same results.
I'll try to get dmesg output...
28 Jan 2012 12:35 #17223 by Nick
after appling /etc/init.d/realtime start
we got this:
gena@gena-desktop:~$ sudo /etc/init.d/realtime start
[sudo] password for gena:
gena@gena-desktop:~$ halcmd loadrt hm2_7i43 CONFIG="firmware=hm2/7i43-4/SVST4_4_7I39.BIT num_encoders=3 num_3pwmgens=3 num_stepgens=2"
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/emc2/hm2_7i43.ko': -1 Unknown symbol in module
<commandline>:0: exit value: 1
<commandline>:0: insmod failed, returned -1
See the output of 'dmesg' for more information.
[   94.980624] I-pipe: Domain RTAI registered.
[   94.980643] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[   94.980650] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[   94.980764] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[   94.980771] PIPELINE layers:
[   94.980780] f8c11e20 9ac15d93 RTAI 200
[   94.980787] c085cb20 0 Linux 100
[   95.030826] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[   95.031406] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[   95.031418] RTAI[sched]: hard timer type/freq = APIC/12500388(Hz); default timing: periodic; linear timed lists.
[   95.031425] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799956000 hz.
[   95.031430] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[   95.031558] RTAI[usi]: enabled.
[   95.658919] RTAI[math]: loaded.
[  242.775976] hm2_7i43: Unknown symbol hm2_register
[  242.777333] hm2_7i43: Unknown symbol hm2_unregister
[  414.789699] hm2_7i43: Unknown symbol hm2_register
[  414.790986] hm2_7i43: Unknown symbol hm2_unregister
[  640.913148] hm2_7i43: Unknown symbol hm2_register
[  640.914434] hm2_7i43: Unknown symbol hm2_unregister
[  684.829110] hm2_7i43: Unknown symbol hm2_register
[  684.830460] hm2_7i43: Unknown symbol hm2_unregister
[  738.350656] hm2_7i43: Unknown symbol hm2_register
[  738.351943] hm2_7i43: Unknown symbol hm2_unregister
[ 1081.514359] hm2_7i43: Unknown symbol hm2_register
[ 1081.515646] hm2_7i43: Unknown symbol hm2_unregister
28 Jan 2012 15:53 #17235 by PCW
Is there some reason you are not simply running emc (LinuxCNC) from the command line?
I would first either install EMC2.5 or 2.6 or compile and run-in-place (remembering to set the run-in-place environment so you actually get 2.5/2.6) Then check that the sample 7I43 configs launch properly
If this works ok I would make a new config from the sample config. changing only the firmware
load line so the new firmware is loaded (but delete all the encoder/stepgen/pwmgen info on the load line so all modules are automaticaly enabled)
Moderators: PCWjmelson
Time to create page: 0.253 seconds
