Mesa 7I44-7I70/7I71
19 Dec 2011 00:45 #15821 by PCW
Replied by PCW on topic Re:Mesa 7I44-7I70/7I71
Looks like you have the case wrong
[ 4426.285312] hm2_5i23.0: firmware: requesting hm2/5i23/rmsvss6_8.BIT
but the file I made is rmsvss6_8.bit
19 Dec 2011 00:52 #15822 by SRT
Replied by SRT on topic Re:Mesa 7I44-7I70/7I71
I see that now but i just tried to fix it and still returns the same error. I downloaded it and it it in the directory. Latest error report
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/lib/tcltk/emc2
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.5.0-pre2-422-gecd2cf4
Machine configuration directory is '/home/srt/emc2/configs/10CC'
Machine configuration file is '10CC.ini'
INIFILE=/home/srt/emc2/configs/10CC/10CC.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Shutting down and cleaning up EMC2...
Running HAL shutdown script
Killing task emcsvr, PID=4918
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/emc2/hm2_pci.ko': -1 Unknown symbol in module
10CC.hal:9: exit value: 1
10CC.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
4918
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[14279.547507] I-pipe: Domain RTAI registered.
[14279.547522] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[14279.547527] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[14279.547606] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[14279.547611] PIPELINE layers:
[14279.547616] fd686e20 9ac15d93 RTAI 200
[14279.547621] c085cb20 0 Linux 100
[14279.593037] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[14279.593510] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[14279.593522] RTAI[sched]: hard timer type/freq = APIC/12499628(Hz); default timing: periodic; linear timed lists.
[14279.593529] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1800080000 hz.
[14279.593535] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[14279.593658] RTAI[usi]: enabled.
[14279.678415] RTAI[math]: loaded.
[14279.805889] hm2: loading Mesa HostMot2 driver version 0.15
[14279.811317] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[14279.811374] hm2_pci 0000:03:00.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[14279.811382] hm2_pci: discovered 5i23 at 0000:03:00.0
[14279.811570] hm2_5i23.0: firmware: requesting hm2/5i23/rmsvss6_8.bit
[14279.815302] hm2/hm2_5i23.0: firmware hm2/5i23/rmsvss6_8.bit not found
[14279.815312] hm2/hm2_5i23.0: install the package containing the firmware.
[14279.815321] hm2_5i23.0: board fails HM2 registration
[14279.815353] hm2_pci 0000:03:00.0: PCI INT A disabled
[14279.815369] hm2_pci: probe of 0000:03:00.0 failed with error -2
[14280.444324] hm2: unloading
[14280.516481] RTAI[math]: unloaded.
[14280.557659] SCHED releases registered named ALIEN RTGLBH
[14280.588426] RTAI[malloc]: unloaded.
[14280.692022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[14280.697651] I-pipe: Domain RTAI unregistered.
[14280.697741] RTAI[hal]: unmounted.
19 Dec 2011 00:54 #15823 by SRT
would the ini and the hal file help?
19 Dec 2011 01:12 - 19 Dec 2011 01:13 #15824 by PCW
Not at this point (where the driver exits because it cannot find the selected firmware)
The firmware (rmsvss6_8.bit) needs to be installed in /lib/firmware/hm2/5i23
This will require root privleges
Last edit: 19 Dec 2011 01:13 by PCW. Reason: om
19 Dec 2011 16:00 #15840 by SRT
I copied the rmsvss6_8.bit file to the correct dir and what do you know it worked. Now I have other faults but I did make progress. Being a newby I am learning Linus as well as EMC. Thank you for the direction. Now for another question the error I get now is 'hm_25i23.0.encoder.00.counter-mode'
not found. Does this mean EMC is not seeing or finding the 7149 board? Thanks again....I Promise to research my own issues but I just don't know where to look yet and without any examples to follow I will have to rely on direction from this forum. If there is any one section of the manuals I need to study please tell me.
19 Dec 2011 16:08 #15842 by PCW
I means there are no encoders in the rmsvss config (only resolvers)
which means the num-encoders=N statement in your ini file needs to be changed to num_resolvers
(plus any reference to "encoders" in the HAL file need to be replaced by the resolver equivalent)
man hostmot2 should give you the names of the resolver signals
19 Dec 2011 17:33 #15845 by andypugh
Replied by andypugh on topic Re:Mesa 7I44-7I70/7I71
I tend to start here:
www.linuxcnc.org/docview/2.5/html/
In your case you want this bit:
www.linuxcnc.org/docview/2.5/html/drivers/hostmot2.html
But that manually-written page is a little outdated. However if you scroll further down the first linked page I gave you to the section that lists individual realtime components you will find:
www.linuxcnc.org/docview/2.5/html/man/man9/hostmot2.9.html
Which is the up-to-date html of the man page (which you can also get by typing "man hostmot2" in the terminal.
19 Dec 2011 19:42 #15854 by cmorley
Replied by cmorley on topic Re:Mesa 7I44-7I70/7I71
How are you making your HAL file?
19 Dec 2011 20:06 #15855 by SRT
I started with pncconf to get a basic layout of the ini and the hal files. I will be hand editing the rest. My configuration is just too complicated for the current version of pncconf. I also need to learn HAL because I have at least three more machines that I would like to retrofit and the more I know the better off I will be. Thanks for the links to the doc's I have printed the manuals I just can not find what I am looking for because for the most part I do not know what i am looking for yet. It took me all day yesterday just the learn how to copy my firmware file into the lib/hm2/firmware/5i23 directory. I am learning Linux at the same time.
19 Dec 2011 20:12 #15856 by andypugh
If it makes you feel any better, I was in exactly the same position a couple of years ago.
The search box over there <=== is your friend. (though why the first search result is pushed below the level of the left bar is a mystery to me)
Moderators: PCWjmelson
Time to create page: 0.160 seconds
