- Thank you received: 11
Mesa 7i96 driver/setup Plasma Table
- snugglylovemuffin
8 years 3 months ago #114178
by snugglylovemuffin
Replied by snugglylovemuffin on topic Mesa 7i96 driver/setup Plasma Table
Thanks to you guys, I was able to fix my networking issues and successfully ping the card; as well I've modified the ini/hal files.
However when I start linuxcnc, I get an error "hm2_eth" module not being found within the 3.4-9-rtai-686-pae file set. However, if I boot into 3.2.0-4 I get another error, which I conveniently didn't write down.
I'll try booting back into 3.2.0-4 and see if I can work this out or at least get a definitive error. Do I just need to install the hm2_eth module manually on 3.4-9/
- snugglylovemuffin
8 years 3 months ago #114179
3.2 says it needs 3.4-9 realtime in order to run. Guess I need to repair the other error. I popped into synaptic and tried to find out if I could manually install the hm2_eth but I couldn't anything related.
- Thank you received: 5334
8 years 3 months ago #114180
Replied by PCW on topic Mesa 7i96 driver/setup Plasma Table
The hm2_eth module is not compatible with RTAI so will not work with the3.4-9-rtai-686-pae kernel
8 years 3 months ago #114183
That error is likely because you have installed a Preempt-RT kernel but you have not installed the uspace version of LinuxCNC. Probably the easiest way to get the required version for Wheezy is to fetch the LinuxCNC master package for Wheezy from the buildbot:
buildbot.linuxcnc.org/
The following user(s) said Thank You: snugglylovemuffin
- snugglylovemuffin
8 years 3 months ago - 8 years 3 months ago #114185
OHHHHHHH, my bad; I didn't manually insert the proper address for the master branch and just selected the version that was already present.
Last edit: 8 years 3 months ago by snugglylovemuffin.
- snugglylovemuffin
8 years 3 months ago - 8 years 3 months ago #114190
Repositories have been added, uspace installed; getting a new exciting error!
Debug file info:
Note: Using POSIX non-realtime
hm2_eth: rtapi_app)main: Connection refused (-111)
Looks like my HAL file isn't playing nice.
I use pncconf to make a 7i76e file and then replaced card callouts with 7i96; from what I was reading, that should work... right?
EDIT:
Reading through another thread for the card. I had previously manually setup a network, apparently I didn't provide the default MAC. When I read the thread previously and was able to successfully ping my card.
Other thread ---> forum.linuxcnc.org/27-driver-boards/3276...ernet-board?start=10
Debug file info:
EDIT:
Time to create page: 0.149 seconds
