- Thank you received: 11
Mesa 7i96 driver/setup Plasma Table
- snugglylovemuffin
8 years 3 months ago - 8 years 3 months ago #114404
by snugglylovemuffin
Replied by snugglylovemuffin on topic Mesa 7i96 driver/setup Plasma Table
haha I was just reading though them in order to make sure I wasn't missing anything. Pardon my ignorance. I'm going through the process now and I'm having a problem changing permissions in the network folder of the file system.
linuxcnc.org/docs/html/man/man9/hm2_eth.9.html
I was unable to add the script to the "setup" document in the "interfaces.d" (I'm assuming that's the document I need to modify, contextually it has an eth0 script)
I attempted to change permissions by using: chmod +rwx "interfaces-d", I was however denied permission.
the address will be changed 10.10.10.10
Last edit: 8 years 3 months ago by snugglylovemuffin.
- Thank you received: 5334
8 years 3 months ago #114407
Replied by PCW on topic Mesa 7i96 driver/setup Plasma Table
Please dont change the permissions/modes of any system file
The instructions in the hm2_eth manual page state
Configure network with static address
Add these lines to the file /etc/network/interfaces to configure eth1
with a static address:
auto eth1
iface eth1 inet static
address 192.168.1.1
hardware-irq-coalesce-rx-usecs 0
You will have to change the ip address in the file to say 10.10.10.1 and probably change the device name, Also the "hardware-irq-coalesce-rx-usecs 0" is typically only appropriate for Intel MACs
to edit the interfaces file you use sudo:
sudo mousepad /etc/network/interfaces
You can also avoid all this and use the network manager to setup the MAC
auto eth1
address 192.168.1.1
The following user(s) said Thank You: snugglylovemuffin
- snugglylovemuffin
8 years 3 months ago #114414
Starting to get really frustrated... I'm getting the exact same error despite all of these efforts. I added the script to "interfaces" and made sure to change the address.
Will "hardware-irq-coalesce-rx-usecs 0" hurt if it's not an intel network card?
Still says "posix realtime"...
- Thank you received: 7491
8 years 3 months ago - 8 years 3 months ago #114428
BTW, start with a fresh installation, changing system file permissions is not good in any way shape or form.
Replied by tommylight on topic Mesa 7i96 driver/setup Plasma Table
As mentioned by PCW earlier, it should say that, it should be "posix realtime". That is the only way Linuxcnc will be able to control hardware. Non-realtime is for simulation and testing only.snugglylovemuffin wrote:
Last edit: 8 years 3 months ago by tommylight. Reason: more info
- snugglylovemuffin
8 years 3 months ago #114429
Ah okay, I thought it was supposed to say "preept-rt"
Good idea: I botched my dual boot anyway lol.
8 years 3 months ago #114433
"posix realtime" is correct
"hardware-irq-coalesce-rx-usecs 0" will probably just cause an error with a Realtek MAC so really only for Intel and some Broadcom chips
what does ip a report now?
Time to create page: 0.314 seconds
