- Thank you received: 5334
Mesa 7i96 driver/setup Plasma Table
8 years 3 months ago #114500
Replied by PCW on topic Mesa 7i96 driver/setup Plasma Table
Here are detailed instructions for general Debian network setup:
wiki.debian.org/NetworkConfiguration#Con...e_interface_manually
You can also use the GUI (little icecream bar looking icon on the top right of the screen)
Also tommylights IP address notes are correct, the 7I96 card is at 10.10.10.10 so the host has to be at a different address (but in the same 10.10.10.X subnet)
The following user(s) said Thank You: snugglylovemuffin
- snugglylovemuffin
- Thank you received: 11
8 years 3 months ago - 8 years 3 months ago #114501
by snugglylovemuffin
Replied by snugglylovemuffin on topic Mesa 7i96 driver/setup Plasma Table
LMAO, I would be so annoyed right now if it wasn't for the fact that it just started right up without any errors.
Just needed to change that ip address. I had thought network manager and connections were different.
Sweet, just need to setup the HAL for proma and relay.
Last edit: 8 years 3 months ago by snugglylovemuffin.
- snugglylovemuffin
8 years 3 months ago - 8 years 3 months ago #114729
Yeesh. I need to modify the Toma plasma setup to work with my mesa board. Is this a process of changing directories and files? i.e. put the Toma files into my 7i96 directory, keeping my .ini and .hal from the 7i96 and updating them with the information from the Toma files?
- Thank you received: 7491
8 years 3 months ago #114732
Replied by tommylight on topic Mesa 7i96 driver/setup Plasma Table
You just need to replace the paraport pins to mesa pins in the toma files, example :
net StepX stepgen.0.step => parport.0.pin-02-out
net DirX stepgen.0.dir => parport.0.pin-03-out
to
hm2_7i96.0.stepgen.07.xxxxxxxx <===== ??? do not know what goes here, PCW, helppppp !
Also the inputs and outputs should be changed accordingly.
to
- Thank you received: 4153
8 years 3 months ago #114733
Replied by rodw on topic Mesa 7i96 driver/setup Plasma Table
A different card, but this example for a 7i76e should point you in the right direction to configure the stepgens
forum.linuxcnc.org/47-hal-examples/34072...antry-example#106523
- snugglylovemuffin
8 years 3 months ago #114757
So I'll need to change pins to:
hm2/hm2_7i96.0. IO Pin 000 (01-01[TB 1,2,3 then pin?]): IO Port <(denote function?)
I.E.
hm2/hm2_7i96.0. IO Pin 33 (03-14): net estop-ext
OR
net estop-ext <= hm2_7i96.0.gpio.033.in
I may be confusing the .hal/.ini setup; but I think I'm onto something
I.E.
OR
Time to create page: 0.206 seconds
