- Thank you received: 11
Mesa 7i96 driver/setup Plasma Table
- snugglylovemuffin
8 years 3 months ago - 8 years 3 months ago #114758
by snugglylovemuffin
Replied by snugglylovemuffin on topic Mesa 7i96 driver/setup Plasma Table
You've already run this plasma cnc gambit, IIRC. Did you use the Proma THC?
Last edit: 8 years 3 months ago by snugglylovemuffin.
- Thank you received: 5334
8 years 3 months ago #114760
Replied by PCW on topic Mesa 7i96 driver/setup Plasma Table
TB3 pins 1 through 11 = inputs 0 through 10 = gpio 0 through 10, like
hm2_7i96.0.gpio.000.in = TB3.1
TB3 isolated outputs are named ssr like
hm2_7i96.0.ssr.00.out-00 = TB3 pins 13,14
The following user(s) said Thank You: snugglylovemuffin
- snugglylovemuffin
8 years 3 months ago - 8 years 3 months ago #114763
Thank you!
Can you give me an example of how to setup the pins for the motors in the .hal?
So far I've setup a basic line: setp hm2_7i96.0.stepgen.00.??????
What is the designation for step +/- or dir +/-?
- snugglylovemuffin
8 years 3 months ago #114904
The CR11 (INIT) led turns red and stays on after power up the board. The manual says that this could indicate a problem with the FPGA setup; I've not begun to think about using the mesaflash utility, let alone alter the FPGA settings.
8 years 3 months ago #114923
This is normal with newer Ethernet firmware, if Linuxcnc has been running so the watchdog is enabled, the red /INIT LED indicates that the Watchdog has bitten.
- snugglylovemuffin
8 years 2 months ago #115463
I've integrated most of the thc components, however the relay output hm2_7i96.0.ssr.00.out-00 causes linuxcnc to say "pin doesn't exist".
Time to create page: 2.390 seconds
