- Thank you received: 4153
Mesa 7i96 driver/setup Plasma Table
8 years 2 months ago #115468
Replied by rodw on topic Mesa 7i96 driver/setup Plasma Table
Just use halshow to look at your machine configuration and you will see the pin names. Work out which one you are using for your relay. Then it is just a matter of changing your hal file to suit.
The following user(s) said Thank You: snugglylovemuffin
- snugglylovemuffin
- Thank you received: 11
8 years 2 months ago - 8 years 2 months ago #115471
by snugglylovemuffin
Replied by snugglylovemuffin on topic Mesa 7i96 driver/setup Plasma Table
An frack... I didn't add the output to the machine hal; probably the problem
Net TorchOn => hmw_7i96.0.ssr.00.out-00 ????
I'm assuming you're familiar with the Toma file. Dealing with networking issues on my Linux machine, otherwise I'd post the files
Last edit: 8 years 2 months ago by snugglylovemuffin.
- snugglylovemuffin
8 years 2 months ago #115473
Okay, I fixed the problem; thanks Rodw!
- Thank you received: 7491
7 years 8 months ago #126113
Replied by tommylight on topic Mesa 7i96 driver/setup Plasma Table
Added the config that should work with 7i96.
forum.linuxcnc.org/plasma-laser/34978-th...-with-how-to?start=0
- grijalvap
- Thank you received: 63
6 years 6 months ago - 6 years 6 months ago #162633
by grijalvap
Replied by grijalvap on topic Mesa 7i96 driver/setup Plasma Table
hi I have the same problem with the mesa 7i96
eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 78:d0:04:21:ce:e3 brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/24 brd 10.10.1.255 scope global eth1
valid_lft forever preferred_lft forever
inet 10.10.10.10/24 brd 10.10.10.255 scope global secondary eth1
inet6 fe80::7ad0:4ff:fe21:cee3/64 scope link
Linux Cortadora2 4.9.0-8-rt-686-pae #1 SMP PREEMPT RT Debian 4.9.110-3+deb9u6 (2018-10-08) i686 GNU/Linux
any idea?
any idea?
Last edit: 6 years 6 months ago by grijalvap.
- Thank you received: 5334
6 years 6 months ago - 6 years 6 months ago #162635
Replied by PCW on topic Mesa 7i96 driver/setup Plasma Table
You host MAC is misconfigured
It seems you have an aliased IP address that matches the 7I96 (10.10.10.10)
this will prevent access to the 7I96
Take a look at the hm2_eth manual page for information on setting up a static
IP address in the interfaces file.
Last edit: 6 years 6 months ago by PCW.
Time to create page: 0.155 seconds
