7i96 Configuration Tool
7 years 10 months ago #122354 by tommylight
Replied by tommylight on topic 7i96 Configuration Tool
7i92 is technically the same as 5i25 or 6i25, the only difference is it uses ethernet to communicate with the computer.
Pncconfig has provisions for 5i25, so you make a 5i25 config, open the hal file with gedit or pluma or mousepad and replace every 5i25 to 7i92.
That does not apply to firmware, do not use 5i25 firmware on a 7i92.
7 years 10 months ago #122545 by tcalow
Replied by tcalow on topic 7i96 Configuration Tool
Hello BigJohnT,
I have tried out your configuration tool on a fresh install of the Debian Stretch, RT-PREEMPT live CD. I get an error Pin 'joint.0.amp-enable-out' does not exist. I am new to LinuxCNC but I think that this pin should be created by motmod. Im not sure why it's not there. If I comment out that line I get an error that pin joint.0.motor-pos-cmd does not exist. I have attached my hal, ini and the Error file. Any insight would be greatly appreciated.
Thanks,
Tyler
7 years 10 months ago #122572 by PCW
Replied by PCW on topic 7i96 Configuration Tool
It looks like the configuration tool is written for LinuxCNC 2.8, not 2.7 so will have many
"axis" -- "joint" name issues if you try to run a config on a LinuxCNC 2.7 system
The following user(s) said Thank You: BigJohnT, Ewok2
7 years 10 months ago #122747 by Ewok2
Replied by Ewok2 on topic 7i96 Configuration Tool
Wonderful tools !!!
Just 2 comments :
- In the Axis tab / Joint in the joint information, I get a distance to accelerate to max speed in inches despite the fact I select the Metric system in the First Tab :-)
- In the PC Tab, when I select the Read tMax I did not get a value in return ?
7 years 10 months ago #122776 by Ewok2
Hello BigJohnT
I had a configuration working.
I open the ini file with your tools and do the minimum of modification for the check to be Ok (Pass in Metric, put the scale to 1 and assign Joint to axis)
But when I execute LinuxCnc after building with your tool I get 2 Error messages :
- Unexpected realtime delay on task 0 with period 100000. Run the Latency Test and resolve before continuing.
- hm2/hm2-7i96.0 : error finishing read! iter=6
Any idea of the reason ?
7 years 10 months ago #122777 by PCW
Yes, you have the servo thread period way too short
Typical servo thread period is 1 ms (1000000 ns)
Moderators: PCW, jmelson
Time to create page: 0.092 seconds
