Ewok2 wrote: Wonderful tools !!!
Just 2 comments :
- In the Axis tab / Joint in the joint information, I get a distance to accelerate to max speed in inches despite the fact I select the Metric system in the First Tab
- In the PC Tab, when I select the Read tMax I did not get a value in return ?
Ewok2 wrote: Yes you are right with 1000000 it is better.
It seem's that the tools 7i96 put it again to 100000 even if previous ini file had 1000000.
pl7i92 wrote: Is someone doing simultaneity to 7i92 ?
Ewok2 wrote: - In the PC Tab, when I select the Read tMax I did not get a value in return ?
