7i96 Configuration Tool
7 years 5 months ago #134593 by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool
I just pushed a couple of bug fixes to the 7i96 repo to fix flashing the card from the configuration tool.
JT
The following user(s) said Thank You: TheFabricatorAG, nbremond
7 years 5 months ago #134605 by nbremond
Replied by nbremond on topic 7i96 Configuration Tool
Thanks... it's currently compiling the kernel...
7 years 5 months ago #134608 by AgentWD40
Replied by AgentWD40 on topic 7i96 Configuration Tool
Just in case you weren't aware you can get debian stretch with rtpreempt precompiled in a live cd/usb here
www.linuxcnc.org/testing-stretch-rtpreempt/
The following user(s) said Thank You: snugglylovemuffin
7 years 5 months ago #134616 by nbremond
Thanks. It'll be the plan B in case the compiling process fail... compiling the kernel takes forever...
7 years 5 months ago #134738 by nbremond
Everything compiled and installed without issue on Mint 19.
And the 7i96 configuration tool is also working.
Thanks for your help
7 years 5 months ago #134946 by Project_Hopeless
Dumb question, how do I launch the tool? I think it installed correctly
anto@CNCRouter:~$ pip3 install /home/anto/Downloads/7i96-master/
Processing ./Downloads/7i96-master
Building wheels for collected packages: 7i96
Running setup.py bdist_wheel for 7i96 ... done
Stored in directory: /home/anto/.cache/pip/wheels/81/09/41/a1eb76abe81b88106144bb8fcad1e4ee4e3c6ece133634ab39
Successfully built 7i96
Installing collected packages: 7i96
Successfully installed 7i96-0.1.0
Moderators: PCW, jmelson
