7i96 Configuration Tool
8 years 2 months ago #116524 by BigJohnT
Replied by BigJohnT on topic 7i96 Configuration Tool
The PLC tab where you can add classicladder and change the default number of items.
JT
8 years 2 months ago #116525 by BigJohnT
Last but not least the important tabs for Ethernet cards a way to find out if your PC is a good candidate for an Ethernet Mesa card.
The info tab you can get the CPU information and the NIC information.
The pc tab you can get the tmax value and with the CPU speed calculate the amount of the servo period it uses.
JT
The following user(s) said Thank You: kb8wmc, tommylight, rodw, snugglylovemuffin
7 years 11 months ago #119950 by snugglylovemuffin
You're the best BigJohnT!
It's great to see the 7i96 board being more thoroughtly supported!
7 years 11 months ago #119994 by andypugh
Replied by andypugh on topic 7i96 Configuration Tool
I am curious, why a separate tool rather than adding the board to pncconf?
7 years 11 months ago #120051 by BigJohnT
Two reasons, simplicity in configuration is the overwhelming drive for me to write it. IMHO it's easier for a NewBee to use a tool designed for the card and not have so many selections to try and understand.
I didn't write pncconf so I don't know anything about it. I tried to look at it once but you needed something special to open it (I forget it's been a long time) so I quit. Even I get confused trying to build a configuration with pncconf...
JT
The following user(s) said Thank You: Ewok2
7 years 10 months ago #122185 by pl7i92
Replied by pl7i92 on topic 7i96 Configuration Tool
Is someone doing simultaneity to 7i92 ?
Moderators: PCW, jmelson
