- Thank you received: 178
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- TOLP2
4 years 4 months ago #244709
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Best is to recompile the driver everytime there is a new commit. Changes in the firmware are often combined with a difference in driver.
- muvideo
- Thank you received: 30
4 years 4 months ago #244724
by muvideo
Replied by muvideo on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Tested in Linuxcnc 2.8.2 conf with one stepgen few outputs and 3 pwm, stepgen still not working, is responding with strange numbers on it's pins.
- TOLP2
4 years 4 months ago - 4 years 4 months ago #244735
by TOLP2
I tested the firmware with the following configuration
With this configuration I can run tests on all three stepgens and the data is received correctly. I used the following hal-commands to test it:
As you can see, I run at fairly low frequency, because for ach period I print out the complete debug of the stepgen, which includes commanded position, received position, estimated position, etc. Those numbers look correct.
Is there a possibility that either the driver or the firmware is not the latest version? The latest commit hash-tag is 1d6e37e
"board_name": "test_PWM_GPIO",
"baseclass": "firmware.boards.ColorLight_5A_75E_V6_0",
"clock_frequency": 50000000,
"ethphy": {
"tx_delay": 0
"etherbone": {
"ip_address": "10.0.0.10",
"mac_address": "0x10e2d5000000"
"gpio_in": [
{"pin":"j12:0", "name": "optional_name_unique"}
"gpio_out": [
{"pin": "j1:1"},
{"pin": "j1:5"}
"pwm": [
{"pin": "j1:2"}
"stepgen": [
"step_pin": "j2:1",
"dir_pin": "j2:5",
"soft_stop": true
"step_pin": "j3:1",
"dir_pin": "j3:5",
"soft_stop": true
"step_pin": "j4:1",
"dir_pin": "j4:5",
"soft_stop": true
# This file assumes that the firmware located in ../firmware/5a-75e-stepgen-test/ is loaded
# to the FPGA. The corresponding json-configuration is loacted in the ../../examples
# folder. Modify paths as required for your setup!
# USAGE:
# halrun -I test_Stepgen.hal
loadrt litexcnc
loadrt litexcnc_eth config_file="/home/litexcnc/5a-75e-stepgen-test.json"
loadrt threads name1=test-thread period1=10000000
loadrt siggen
# Add litexcnc and siggen to the thread
addf test_PWM_GPIO.read test-thread
addf siggen.0.update test-thread
addf test_PWM_GPIO.write test-thread
# Setup the watchdog
setp test_PWM_GPIO.watchdog.timeout_ns 15000000
# Some basic setup for stepgen, based on a simple stepper with 200 steps per revolution
# per revolution, could be a simple Polulu DRV8825
setp test_PWM_GPIO.stepgen.02.maxaccel 10.0
setp test_PWM_GPIO.stepgen.02.maxvel 100.0
setp test_PWM_GPIO.stepgen.02.position-scale 200
# Settings for a Leadshine DM542, with timing multiplied by a factor 2
setp test_PWM_GPIO.stepgen.02.steplen 5000
setp test_PWM_GPIO.stepgen.02.stepspace 5000
setp test_PWM_GPIO.stepgen.02.dir-hold-time 10000
setp test_PWM_GPIO.stepgen.02.dir-setup-time 10000
# Enable the stepgen and
setp test_PWM_GPIO.stepgen.02.enable 1
# Create a siggen and connect the sinus-soidal signal to the position of the stepgen
setp siggen.0.frequency 0.25
# net stepgen-pos siggen.0.square => test_PWM_GPIO.stepgen.02.position-cmd
net stepgen-pos siggen.0.sine => test_PWM_GPIO.stepgen.02.position-cmd
setp test_PWM_GPIO.stepgen.02.debug TRUE
Last edit: 4 years 4 months ago by TOLP2.
The following user(s) said Thank You: svb
- svb
- Thank you received: 10
4 years 4 months ago #244974
by svb
Replied by svb on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Hi All
In the Litex description of the board, I found the "serial" section, which seems to be responsible for RS 232 or similar interfaces. How would one use this functionality to control a spindle connected via RS 485? Right now I'm using USB Dongle USB-RS485. The scheme of the electronic part is drawn, how to bring the serial port to the contacts that are indicated in the description of the board (or to any others, as I understand it, it doesn’t matter which ones)
- romanetz
- Thank you received: 45
4 years 4 months ago #244987
by romanetz
Replied by romanetz on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Right now, this function is not implemented yet. In general, a FIFO is needed inside the board to maintain continuous transmission of serial data. Say, for 1 msec servo period and serial speed 921600, a FIFO must have capacity 115 bytes. Taking into account that Etherbone protocol is limited to 256 bytes for a single transaction and some amount of data is already occupied, I estimate that something around 1-2 Mbits/sec is achievable.
Also there are some parameters that aren't needed to be sent every servo period: pulse length, step length; they could be considered as constants for the application.
- TOLP2
4 years 4 months ago #245025
by TOLP2
Also in Litex-CNC this is not implemented yet. I don't think it will be implemented this year, unless people want to contribute to the project. First I want to focus on getting my version working 100% reliable. At this moment the modules GPIO out, PWM and stepgen work perfectly fine. Muvideo reported errors with the GPIO in, which I haven;t been able to reproduce. Coming week I get a shipment of 74LVC245 chips, so I can also start experimenting with the inputs.
About creating some more space in the etherbone packet by setting some parameters as constants is interesting. I think the list will be limited to parameters of the stepgen. Does a write-once HAL param exist? Otherwise such a write-once behavior can wreak havoc if somebody is not aware of the effects....
With RS-485 it is also important to remember that for different VFD's there are different commands and thus drivers. Those drivers assume that they can write to /dev/serial## for sending commands. So, it does not only require extension of the ColorCNC / Litex-CNC, but also modification of the specific driver on the VFD. The structure of Litex-CNC would allow to create an 'on-board' driver, with only sending commands for spindle speed to the FPGA, where the FPGA will translate them to RS-485 commands. In Python is easy to define multiple drivers for the different brands of VFD's.
Time to create page: 8.095 seconds
