- Thank you received: 30
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- muvideo
4 years 3 months ago #248328
by muvideo
Replied by muvideo on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Hi, in your screnshots I see that Lcnc.00.enabled Is false, so the board Is disabled. Try to move Lcnc.00.enable-request to true (keep Lcnc.00.enable to true) and check if enabled becomes true.
Is the communication with the board working ok? How much Is the value of watchdog-read pin?
- svb
- Thank you received: 10
4 years 3 months ago - 4 years 3 months ago #248331
by svb
Replied by svb on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Last edit: 4 years 3 months ago by svb.
- muvideo
4 years 3 months ago - 4 years 3 months ago #248333
by muvideo
So there must be something that resets the board.
Suspects are:
- external reset input (in my script is routed to pin j4:6) be sure to have that pin to zero
- tx retries, if the communication is healty it should be no problem, but in doubt you can raise the value of Lcnc.00.tx-max-retries to an higher value
- watchdog (this is the first thing I owuld check): Lcnc.00.watchdog-write should be way higher than the thread period you are running at, I'm using 10ms (0.01) with 1ms thread period, you can monitor Lcnc.00.watchdog-read to see if it is dangerously near zero.
For testing you can raise Lcnc.00.watchdog-write to a very high value (tops out at about 5s).
Let me know how these values are now.
By the way, keep in mind that enable-request is evaluated only on it's rising edge false to true, so connect it to some input that you can toggle at runtime
Suspects are:
Last edit: 4 years 3 months ago by muvideo.
- svb
4 years 3 months ago - 4 years 3 months ago #248358
by svb
- muvideo
4 years 3 months ago #248360
by muvideo
Oh, I'm happy it started working, let me know of any problems bugs or quirks you find.
- svb
4 years 3 months ago - 4 years 3 months ago #248361
by svb
Extremly low speed
I.e. if i set feedrate 5mm/min, and set move to less than 20mm, i'm always arrive to destination (+-0.003mm).
If feedrate greater 5mm/min or distance to go greater 20mm i never arrive to destination. Joint error. Always.
I'm try to change *FERROR parameters but nothing changed
This is for stepgen module.
Input worked. BUT! Not reading at start. Im have DCRS-01J rotary switch for setting feedrate as on Siemens MCP, and while im not change switch position, always readed 100%.
I'm try to move config section for my component in any places of a config - nothing happened
Update.
Run G1X10F10 from X20 position
Arrived to 10.159 instead 10.00
Extremly low speed
Update.
Time to create page: 1.730 seconds
