- Thank you received: 10
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- svb
4 years 2 months ago #249065
by svb
Replied by svb on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
@vit74vit, Please read cnc-club personal message
- TOLP2
- Thank you received: 178
4 years 2 months ago #249475
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Woo, this thread exploded while on holiday. Good to see you active and many thanks to svb to help other users out.
As the problems with stepgen still persist, I will look into that coming weekend.
- vit74vit
- Thank you received: 4
4 years 2 months ago #249575
by vit74vit
Replied by vit74vit on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Dear Peter.
I found a bug in the register reading function from the FPGA.
In driver package has structure: Watchdog (32),WallClock(64),GPIO_IN(32), .......
In reality, there is no Watchdog in the package.
The starting address of the read buffer is shifted by the size of Watchdog (32), which leads to errors described by me and SVB.
P/S: Peter, you can post an example of how to use litexcnc_debug, now I have added the debug info to litexcnc.c.
The following user(s) said Thank You: TOLP2
- TOLP2
4 years 2 months ago #249623
by TOLP2
Which method did you use to print this out?
To check whether the watchdog data is missing or the datastream is mis-aligned I would like to have your configuration.
I'm very keen on solving this problem. With the data from svb I've verified so far:
- it is not due to an error in the driver (I replaced the driver and it still worked)
- it is not due to an error in the HAL-file (his HAL-file works with my card).
Other words: I was not able to reproduce the error. Next step is to verify the firmware. Somewhere something has changed, now to find where. Thanks a lot for the lead to look.
- romanetz
- Thank you received: 45
4 years 2 months ago #249633
by romanetz
Replied by romanetz on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Can you show the firmware compilation report?
I mean, if a logic design cannot handle working frequency properly (so called "timing slacks"), one will get some strange unreproducible errors.
- vit74vit
4 years 2 months ago - 4 years 2 months ago #249640
by vit74vit
Peter!
i find an error occurred in the size calculation.
The value is 4 bytes larger than it should be. This results in a shift of one register when reading from the FPGA.
file stepgen.h (137)
#define LITEXCNC_BOARD_STEPGEN_DATA_WRITE_SIZE(litexcnc) ((litexcnc->stepgen.num_instances?sizeof(litexcnc_stepgen_general_write_data_t):0) + LITEXCNC_STEPGEN_INSTANCE_WRITE_DATA_SIZE*litexcnc->stepgen.num_instances)
Last edit: 4 years 2 months ago by vit74vit.
Time to create page: 1.606 seconds
