ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
4 years 2 months ago - 4 years 2 months ago #249817 by svb
Hello Peter
As I wrote earlier, I just have the motor connected. And jerks on the screen coincide with jerks on the engine.
I've tried different GUIs: gmoccapy, axis, qtvcp axis. Everywhere the behavior is the same.
Moreover, if I use the Fabio driver and firmware, everything moves smoothly, without jerks, with any GUI, qtdragon also tested.
Also with the Fabio driver, the CPU usage is much less.
On a 32-bit system, this is noticeably even stronger.
Update: After 11 runs of the 3D_Chips program on a 32 bit system, the driver went into the same uncontrolled movement as in the 64-bit version.
Last edit: 4 years 2 months ago by svb.
The following user(s) said Thank You: TOLP2
4 years 2 months ago #249859 by muvideo
Hi, about packet loss behavior, you can try to raise the value of Lcnc.00.tx-max-retries, this Is the Number of missing packets that Will trigger the board self disabling. Default value Is 5, you could set it to some value higher than timeout, for example 100.
4 years 2 months ago #249887 by TOLP2
Update: Due to complaints on speed and stability, I've made some changes in the stepgen algorithm (aims at solving both uncommanded / wrong movement and jerky motion). Also added now timing on all components to find out which function causes a high CPU usage. Tomorrow I'll be able to test it on my FPGA whether it works and will share the timing results. Feel free to test it earlier.
The following user(s) said Thank You: tommylight, besriworld, svb, vit74vit
4 years 2 months ago - 4 years 2 months ago #249920 by svb
Ok, i change it to 100000.
Result the same :(
I try to remove cable from board for 0.1-0.2 sec
100000 retries for 10 sec, i'm right?
4 years 2 months ago #249921 by muvideo
100000 should last about 100s before reset, but I've never timed this, I was more interested in the number of consecutive Lost packets. In this scenario the watchdog will bite for sure way before the 100s, depending in how it is configured.
I've noticed that if I disconnect briefly the cable, the connection Is fully restored only after several seconds, and I dont know why.
Maybe in the next iteration I should introduce better error messages so that the reset reason will be more clear.
My machine Is now fully cabled, I'll soon be able to test the sw on actual hardware.
The following user(s) said Thank You: svb
4 years 2 months ago #249924 by svb
Moderators: PCW, jmelson
Time to create page: 0.686 seconds
