ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- svb
- Thank you received: 10
17 Sep 2022 04:03 #252137
by svb
Replied by svb on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Great work, Peter. Will try to test as soon as possible. Big thanks for your work.
The following user(s) said Thank You: TOLP2
- TOLP2
- Thank you received: 178
17 Sep 2022 06:25 #252140
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
The PC currently used for testing is underpowered for large GCode files. However, I think this weekend I will copy the settings from the machine in the shed and run a lithophane as a test. If it runs the 8 hour job effortlessly, I think it passes the test.
- DePrutser
- Thank you received: 6
18 Sep 2022 11:01 #252250
by DePrutser
Replied by DePrutser on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Thanks for all your hard work. I would like to build this:
LinuxCNC->Colorlight 5A-75E board->milling machine.
I have found a few github repositories (listed below), but they don't seem to contain enough verilog code to contain the complete gateware for the ECP5 FPGA. Where can I find that?
1) This pul request. Stepgen.v contains the module stepgen in the form of verilog source for the FPGA
github.com/LinuxCNC/linuxcnc/pull/1422/c...14270f3b3597a894e6b6
2) This github repository. Stepgen.ice contains verilog source that implements a pwm, a step-direction and general IO pins
github.com/Peter-van-Tol/LiteX-CNC
3) This github repository. This repository does not contain any verlog code
github.com/enjoy-digital/colorlite
Kind regards,
Cedric
Kind regards,
Cedric
- TOLP2
18 Sep 2022 19:20 #252288
by TOLP2
@Cedric:
There is no Verilog in any of the repositories. The code of for the FPGA is being built using LiteX/Migen (hence the name of my version of the firmware-driver-combo). You have chosen a nice card to work with, as the whole toolchain for building the bit-file for the 5A-75E is available on Linux.
If you pull my repository (2) you can follow these steps to build the file:
Flash the resulting .svf file to your 5A-75E and the FPGA is ready. Note that if you power-cycle the card, you have to re-flash it in this stage.
For installing the driver, I would like to revert to the README in the repository.
- install LiteX to generate the code
mkdir LiteX && \
cd LiteX && \
wget https://raw.githubusercontent.com/enjoy-digital/litex/master/litex_setup.py && \
pip3 install --user meson ninja && \
python3 litex_setup.py --init --install --config=standard --gcc=riscv- install yosys for building to the target ECP5.
wget https://github.com/YosysHQ/oss-cad-suite-build/releases/download/2022-02-27/oss-cad-suite-linux-x64-20220227.tgz && \
tar -xvf oss-cad-suite-linux-x64-20220227.tgz -C /opt/ && \
rm oss-cad-suite-linux-x64-20220227.tgz && \
echo '# set PATH so it includes oss-cad-suite' >> /etc/profile && \
echo 'if [ -d "/opt/oss-cad-suite/bin" ] ; then' >> /etc/profile && \
echo 'PATH="/opt/oss-cad-suite/bin:$PATH"' >> /etc/profile && \
echo 'fi' >> /etc/profile- create a configuration file which suits your machine (see for some examples the ./examples directory in the repository)
- generate the code (assuming you are in the terminal in the root of the repository) and build it when successful
python -m firmware path/to/your/config/file
cd [i]card_name[/i]/gateware
chmod +x ./build_colorlight_5a_75e.sh
./build_colorlight_5a_75e.shFlash the resulting .svf file to your 5A-75E and the FPGA is ready. Note that if you power-cycle the card, you have to re-flash it in this stage.
- DePrutser
18 Sep 2022 19:35 #252292
by DePrutser
Thank you for the steps, I've started to document my journey here, I'll add them.
forum.linuxcnc.org/27-driver-boards/4692...c-on-linuxcnc#252287
When I got it working, I'm planning on extending your README.md and sending a pull request.
Cheers,
Cedric
Cheers,
Cedric
- DePrutser
18 Sep 2022 19:49 #252293
by DePrutser
I'm planning to use a couple of closed loop stepper motors [4,5]. This consists of a microcontroller, a power driver, and a angle sensor IC. It can be driven with step/direction inputs, and it then is able to catch up if steps are missed. But this is not reported back to the control system.
It would be cool if the FPGA is able to snoop on the SPI interface of the angle sensor IC [6], and convert that into a virtual encoder. That way LinuxCNC actually knows the angle of the stepper motor. I don't know how often the position is updated though, nor how LinuxCNC deals with an encoder that has a relative low update rate.
[4] github.com/makerbase-mks/MKS-SERVO57A
[5] nl.aliexpress.com/item/1005003891654533....gatewayAdapt=glo2nld
[6] www.allegromicro.com/-/media/files/datas.../a1333-datasheet.pdf
- DePrutser
18 Sep 2022 20:07 #252295
by DePrutser
The angle sensor IC can be programmed to output a Quadrature (A,B,Index) signal.
In the schematic [7] of the MKS-SERVO57A, I see those three pins of the chip (12,13,14) to be floating.
Therefore there's no need to snoop the SPI bus, I can just route the 3 Quadrature pins back into the FPGA board, and patch the firmware of the microcontroller to enable those outputs.
[7] raw.githubusercontent.com/makerbase-mks/...A_V1.0_001%20SCH.pdf
- TOLP2
19 Sep 2022 07:25 #252317
by TOLP2
About the stepgens: just pushed a new commit in which:
Your pull request will be mroe then welcome to help with writing things down![...]
Cheers,
Cedric
- the pick-off (the position of the fixed point) can be set (in code for now, if people want I can make it also user-configurable) with different settings for position, velocity and acceleration. This gives some smoother behavior on the stepper motor. For example, if I use the same pick-off for speed and position, the maximum speed attained will be a step with every clock of the FPGA (50 MHz in my case). This is ridiculously fast and as far as I know there is know stepper driver capable of doing this. The lowest step frequency will be 1 / 2^32 step per clock cycle, which boils down to 0.01 step per second. Especially with very low speeds or with ramping down this might lead to some vibrations. Therefor, the pickoff for velocity is now shifted with an additional 8 bits. The maximum step frequency now becomes 195 kHz, which is reasonable high and close to the max frequency of for example standard Leadshine or Lichuan driver (checked with the DM542). The minimum speed is now 0.00003 steps per second. Audibly this results in a much smoother running of the stepper motor.
- the pick-off for acceleration was already shifted by 16 bits, otherwise it would be always zero. It is now also easy to re-configure this to another value.
- In the firmware the shift of the acceleration relative to the position determines the extra bytes required. For a relative shift of 16 bits, this will consume 3 bytes of extra 'space' for the registers.
- because above lead to changes in both firmware and driver, the version number is bumped. This version number will prevent users from combining incompatible firmware and driver.
The following user(s) said Thank You: besriworld, svb
- DePrutser
20 Sep 2022 05:54 #252376
by DePrutser
LiteX-CNC is now working. Next I'll try to compile the gateware:
forum.linuxcnc.org/27-driver-boards/4692...itex-cnc-on-linuxcnc
- TOLP2
20 Sep 2022 07:14 #252382
by TOLP2
Today a small improvement on the stepgen. When on standstill the stepper produced a buzzing sound, it was switching between two (micro-)steps. For standstill situations I improved the driver to prevent this instability to happen. The stepper is nog silent and still runs smooth.
Time to create page: 0.267 seconds
