- Thank you received: 45
ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
- romanetz
3 years 11 months ago #257145
by romanetz
Replied by romanetz on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Well, it seems to me that nobody can forbid me to learn the technology and make an open-source implementation without having to obtain the ethercat membership?
- Thank you received: 4153
3 years 11 months ago #257160
Replied by rodw on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Well you would be in breach of licence agreements and copyright and you would be exposed to legal action by a large well resourced gobal organisation. It could become expensive....Well, it seems to me that nobody can forbid me to learn the technology and make an open-source implementation without having to obtain the ethercat membership?
- Thank you received: 5334
3 years 11 months ago #257164
Replied by PCW on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
An independent slave implementation should not violate any copyrights,
but it would certainly violate EtherCAT patents.
Note that the Primary EtherCAT patents will expire soon (in the next few years)
- TOLP2
- Thank you received: 178
3 years 11 months ago #257180
by TOLP2
Replied by TOLP2 on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
Let us focus in this thread to the development of a LinuxCNC dirver for the Etherbone protocol and not deviate into grey areas
At this moment I've developed three BOBs for the HUB-75 ports:
For these boards I have some questions:
- Sinking input (GPIO in, slow encoders)
- Sourcing output (GPIO out, PWM)
- Differential stepgen (up to 400 kHz step frequency)
- any suggestions on functions? At this moment I'm looking into a BOB for a fast encoder (up to 1 MHz) and a BOB for a bit more heavy GPIO out, which can be used for a heatbed or extruder like component.
- I was considering to put these boards on PcbWay, which would be an affiliate link. Has anybody experience with this, and would it be acceptable within this community. One is always free to upload the production files to any PCB-producer of their liking.
- romanetz
3 years 11 months ago - 3 years 11 months ago #257193
by romanetz
AI, AO (these are just must-have), RS-485 (spindle VFD communication over modbus RTU), CAN, SPI - for DRO LED displays, I2C. for digital communications a kind of FIFO is needed to match network packet exchange interval and throughput of the serial bus .
it's a point to discuss whether include riscv-cpu in firmware or not, but the possibilities with that options are incredible: any kind of user-defined packet-based digital communication, say, modbus rtu onboard processing, or mapping of modbus rtu registers onto etherbone addresses.
I'm exploring the possibility to update the firmware over network and Lattice dual-boot capability.
Regarding PCBs, jlcpcb.com is very popular among countries near China
Last edit: 3 years 11 months ago by romanetz.
The following user(s) said Thank You: tommylight, besriworld
- muvideo
- Thank you received: 30
3 years 11 months ago - 3 years 11 months ago #257199
by muvideo
Replied by muvideo on topic ColorCNC Colorlight 5A-75E/5A-75B as FPGA controller board
I've updated my repository with some new features:
- unified driver
- acceleration limit in stepgen is now working
- FPGA internal clock for peripherals Is 40MHz and Is passing the timing closure.
- some pre coocked firmware are available
Now the board communicates to driver the peripherals configuration and the driver adapts automatically, no need to rebuild the driver for changes in peripherals or board version or revision. The only change that still require a rebuild of the driver Is the change of ip address. I suppose that there a way to pass parameters to the driver at invocation but still didnt try.
Todo:
- pass to the driver the ip and frequency when invoked
- create a configurator utility for speeding up the board configuration
here you can find the driver, firmwares, template for litex and the hal I'm using in my machine:
github.com/faeboli/Lcnc
if anybody wants to try out my implementation I would be grateful, I was able to test only a pair of boards
Thanks!
- unified driver
Todo:
Thanks!
Last edit: 3 years 11 months ago by muvideo.
Time to create page: 0.634 seconds
