Mesa 7i96 with SPINX1 to control spindle speed
22 Feb 2022 22:50 #235563 by kbec
I saw where one issue was the quotes, the other issue was the SPINDLE_0 and the brackets. I saw where in the ini file, the section is SPINDLE with no number, so I changed that too.
I also got this error:
./io.hal:4: Pin 'spindle.0.on' was already linked to signal 'spindle-enable'
So I commented out this line:
#net spindle-enable <= spindle.0.on
It seems defined in the io.hal
net spindle-on spindle.0.on => hm2_7i96.0.ssr.00.out-00
After that,I got linuxcnc running, but I still don't see the LED for speed lighting up.
22 Feb 2022 23:01 #235564 by PCW
The reason that you have no PWM is that the PWM generator pins
and setup parameters are not present in the hal file
22 Feb 2022 23:25 #235566 by kbec
I am kind of lost now, I am not sure where the wires need to go, or why the PWM isn't in the HAL.
In the firmware part I see:
IO Connections for TB1/TB2
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
5 25 IOPort PWM 0 PWM (Out)
6 26 IOPort PWM 0 Dir (Out)
But in the tool, on the pin tab,
TB2
6 +5v
5 Dir +
4 Dir -
3 PWM +
2 PWM -
1 Ground
I also see this:
mesaflash --device 7i96 --addr 192.168.1.121 --readhmid
Module: PWM
There are 1 of PWM in configuration
Version: 0
Registers: 5
BaseAddress: 4100
ClockFrequency: 200.000 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: StepGen
There are 4 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
ClockFrequency: 100.000 MHz
I am not sure why the config tool isn't putting the PWM signals in there. I do notice it pulls the card ip when I load the ini, but the Board configuration goes to 5 step gens, even though I saved it at 4, and the Step Gens, Encoders, and Spindle PWM revert to Default.
22 Feb 2022 23:54 #235567 by PCW
Those are config tool issues (or maybe how it expects its input data)
I can cobble together a working PWM setup to add to your hal file
Could you post your ini file also so I can use and setup values
there rather than put them all in the hal file
23 Feb 2022 00:15 #235569 by kbec
I had to change the extension for the ini to txt. Thanks
File Name: spintest_2...2-22.hal
File Size:4 KB
File Name: spintest.ini.txt
File Size:3 KB
23 Feb 2022 01:19 - 23 Feb 2022 01:21 #235572 by PCW
Ahh, I think Johns utility has an additional hal file for connections
perhaps io.hal? I would need to see that also
Here are some needed changes in the SPINDLE section of the ini file:
[SPINDLE]
OUTPUT_TYPE = 1
SCALE = 2800
PWM_FREQUENCY = 5000
MAX_RPM = 2800
MIN_RPM = 70
DEADBAND = 0
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
MAX_ERROR = 0
And at minimum in the hal file, replace:
net spindle-vel-cmd-rpm => pid.1.command
with
net spindle-vel-cmd-rpm-abs => pid.1.command
Last edit: 23 Feb 2022 01:21 by PCW.
23 Feb 2022 01:25 #235573 by kbec
io.hal just has the one line:
23 Feb 2022 01:40 #235574 by kbec
Can you tell what pins I should have my PWM and Dir plugged into to go to the spinx? I am confused as to the config tool and firmware differs, and not really sure how to trace it in the hal files if I even can.
thanks again
23 Feb 2022 01:46 #235575 by PCW
Step4+ to 7I96 PWM, Dir4+ to Dir
Also I was wrong about
Thats correct because the PWM sign determines the direction output
Here is a first shot of what's missing (in io.hal):
net spindle-on => hm2_7i96.0.pwmgen.00.enable
net spindle-output => hm2_7i96.0.pwmgen.00.value
setp hm2_7i96.0.pwmgen.pwm_frequency [SPINDLE]PWM_FREQUENCY
setp hm2_7i96.0.pwmgen.00.scale [SPINDLE]SCALE
23 Feb 2022 02:04 #235578 by kbec
I made all the changes, the LED still isn't lighting up, here is some debug output I see in on my screen if it helps any:
iov2:ESTOP changed to 0
EMC_TOOL_ABORT reason=5
Issuing EMC_TASK_PLAN_SYNCH -- ( +516,+24, +0,)
emcTaskPlanSynch() returned 0
Issuing EMC_TASK_SET_STATE -- ( +505,+24, +12, +4,)
hm2/hm2_7i96.0: stepgen.00.maxvel is too big for current step timings & position-scale, clipping to max possible
EMC_LUBE_ON
Issuing EMC_SPINDLE_ON -- ( +1304,+64, +13,1.000000,0.000000,0.000000, +1,)
Issuing EMC_SPINDLE_INCREASE -- ( +1309,+40, +14,0.000000,)
Issuing EMC_SPINDLE_CONSTANT -- ( +1311,+40, +15,0.000000,)
Issuing EMC_SPINDLE_DECREASE -- ( +1310,+40, +16,0.000000,)
Issuing EMC_SPINDLE_CONSTANT -- ( +1311,+40, +17,0.000000,)
Issuing EMC_SPINDLE_DECREASE -- ( +1310,+40, +18,0.000000,)
Issuing EMC_SPINDLE_CONSTANT -- ( +1311,+40, +19,0.000000,)
Issuing EMC_SPINDLE_INCREASE -- ( +1309,+40, +20,0.000000,)
Issuing EMC_SPINDLE_CONSTANT -- ( +1311,+40, +21,0.000000,)
Issuing EMC_SPINDLE_OFF -- ( +1305,+32, +22,)
Issuing EMC_SPINDLE_ON -- ( +1304,+64, +23,-1.000000,0.000000,0.000000, +1,)
Issuing EMC_SPINDLE_OFF -- ( +1305,+32, +24,)
Issuing EMC_TASK_SET_STATE -- ( +505,+24, +25, +3,)
EMC_TOOL_ABORT reason=4
NML_INTERP_LIST(0x55cc35f128c0)::clear(): discarding 0 items
NML_INTERP_LIST(0x55cc35f128c0)::append(nml_msg_ptr{size=24,type=EMC_TASK_PLAN_SYNCH}) : list_size=1, line_number=0
NML_INTERP_LIST(0x55cc35f128c0)::get(): {size=24, type=EMC_TASK_PLAN_SYNCH}, list_size=0
emcTaskPlanLevel() returned 0
task: main loop took 0.111895 seconds
EMC_TOOL_ABORT reason=7
Moderators: PCW, jmelson
Time to create page: 0.228 seconds
