Mesa 7i96 with SPINX1 to control spindle speed
- kbec
- Thank you received: 4
24 Feb 2022 15:12 #235707
by kbec
Replied by kbec on topic Mesa 7i96 with SPINX1 to control spindle speed
This is when the spindle should be running, you can see the changes:
- Thank you received: 5334
24 Feb 2022 15:37 - 24 Feb 2022 15:54 #235709
Replied by PCW on topic Mesa 7i96 with SPINX1 to control spindle speed
The ini file PID values are incorrect for a spindle
They need to be what I posted before:
Oops never mind, I was looking at the wrong PID channel
but:
23 float IN 1 pid.1.command <== spindle-vel-cmd-rpm
The commanded RPM is 1!
You should probably set this to all least 1/2 speed (1400) for initial tests.
Also:
23 s32 RW 0 pid.1.do-pid-calcs.tmax
The 0 time means that there is a missing addf for pid1
The missing addf means the PID 1 output will be stuck at 0
but:
Also:
Last edit: 24 Feb 2022 15:54 by PCW.
- kbec
24 Feb 2022 15:57 - 24 Feb 2022 15:58 #235712
by kbec
Here is another file with the speed increased a bit
23 float IN 301 pid.1.command <== spindle-vel-cmd-rpm
19 float OUT 301 spindle.0.speed-out ==> spindle-vel-cmd-rpm
19 float OUT 301 spindle.0.speed-out-abs ==> spindle-vel-cmd-rpm-abs
float 301 spindle-vel-cmd-rpm
float 301 spindle-vel-cmd-rpm-abs
19 float RO 301 motion.debug-float-0
That was just turning on before. It does increase when I press the + in LinuxCNC, but still no change in the value
29 float IN 0 hm2_7i96.0.pwmgen.00.value <== spindle-output
Last edit: 24 Feb 2022 15:58 by kbec.
24 Feb 2022 15:59 - 24 Feb 2022 16:01 #235714
Yeah, that will stay at 0 until the missing addf is fixed:
addf pid.1.do-pid-calcs servo-thread
Last edit: 24 Feb 2022 16:01 by PCW.
- kbec
24 Feb 2022 16:03 #235716
by kbec
Any idea what the addf should look like? I can add manually and test it. Almost all the documentation is geared towards parallel port or drastically different cards and setups.
24 Feb 2022 16:08 - 24 Feb 2022 16:08 #235717
Last edit: 24 Feb 2022 16:08 by PCW.
- kbec
24 Feb 2022 16:21 - 24 Feb 2022 16:22 #235719
by kbec
Makes sense, but didn't seem to fix anything. value is still at 0.
Last edit: 24 Feb 2022 16:22 by kbec.
24 Feb 2022 16:26 - 24 Feb 2022 16:29 #235721
looks like you have the spindle turned off:
23 bit IN FALSE pid.1.enable <== spindle-enable
or
net spindle-enable pid.1.enable
should be
net spindle-on pid.1.enable
or
should be
Last edit: 24 Feb 2022 16:29 by PCW.
- kbec
24 Feb 2022 17:03 #235727
by kbec
Made this change
#net spindle-enable pid.1.enable
Now the value seems to be working. I will need to check my SPINX out, but at least the signals going in look like they are working now.
kirk@LinuxCNC1:~/linuxcnc/configs/spintest3$ halcmd getp hm2_7i96.0.pwmgen.00.value
0
kirk@LinuxCNC1:~/linuxcnc/configs/spintest3$ Issuing EMC_SPINDLE_ON -- ( +1304,+64, +62,1.000000,0.000000,0.000000, +1,)
1
kirk@LinuxCNC1:~/linuxcnc/configs/spintest3$ Issuing EMC_SPINDLE_INCREASE -- ( +1309,+40, +63,0.000000,)
Issuing EMC_SPINDLE_CONSTANT -- ( +1311,+40, +64,0.000000,)
101
Also attaching the latest hal file for BigJohnT to look at.
I think what fixed it to work was adding
and the change for the enable
I do notice my direction LED comes on and doesn't turn off, whether enabled or not, is that kind of expected?
Thanks a bunch to both of you. John, once you have something else for me to test, just let mw know, I understand if it may take a little while.
0
1
101
- BigJohnT
- Thank you received: 994
24 Feb 2022 18:15 #235734
by BigJohnT
Replied by BigJohnT on topic Mesa 7i96 with SPINX1 to control spindle speed
My internet has been down all day. Anyway pid-1-do-calcs never got in the hal file. As soon as I get internet back up I'll push the fix. Using my phone for internet is painful lol.
JT
JT
Time to create page: 0.213 seconds
