Mesa 7i96 with SPINX1 to control spindle speed
- Thank you received: 5334
23 Feb 2022 02:17 #235579
Replied by PCW on topic Mesa 7i96 with SPINX1 to control spindle speed
Did you set a high spindle speed?
The stepgen errors are because you set too wide step pulses for the
requested step rate (the requested step rate is physically
impossible without violating your specified timing)
- kbec
- Thank you received: 4
23 Feb 2022 05:58 #235581
by kbec
Replied by kbec on topic Mesa 7i96 with SPINX1 to control spindle speed
I think that is coming from my XAxis stepgen which I am not concerned about. I just am trying to get the spindle working with the encoder. In the spindle section I have it set from 70RMP to 2800.
[SPINDLE]
OUTPUT_TYPE = 1
SCALE = 2800
PWM_FREQUENCY = 5000
MAX_RPM = 2800
MIN_RPM = 70
DEADBAND = 0
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
MAX_ERROR = 0
I am trying to just focus on the one thing at the moment. I usually create my config with the pmcconf tool, but I didn't think it could handle the PWM firmware, so I used the 7i96 one.
You also said set scale to 2800, I thought that was for the encoder, that is why I had it at 1600.
[SPINDLE]
OUTPUT_TYPE = 1
SCALE = 2800
MAX_RPM = 2800
MIN_RPM = 70
DEADBAND = 0
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
MAX_ERROR = 0
- BigJohnT
- Thank you received: 994
23 Feb 2022 12:26 #235596
by BigJohnT
JT
Replied by BigJohnT on topic Mesa 7i96 with SPINX1 to control spindle speed
Default PWM frequency has been fixed.The PWM frequency should be set to 5 KHz in the utility
If you dont get PWM output, it would probably be best to
post your hal file here to see where the issue lies..
JT
- BigJohnT
23 Feb 2022 12:39 #235599
by BigJohnT
JT
All these items have been fixed as well.Ahh, I think Johns utility has an additional hal file for connections
perhaps io.hal? I would need to see that also
Here are some needed changes in the SPINDLE section of the ini file:
[SPINDLE]
OUTPUT_TYPE = 1
SCALE = 2800
MAX_RPM = 2800
MIN_RPM = 70
DEADBAND = 0
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
MAX_ERROR = 0
And at minimum in the hal file, replace:
net spindle-vel-cmd-rpm => pid.1.command
with
net spindle-vel-cmd-rpm-abs => pid.1.command
JT
- BigJohnT
23 Feb 2022 13:16 #235602
by BigJohnT
I think I have all the issues fixed and have pushed a new deb.
What should setp pid.3.maxoutput [SPINDLE]MAX_OUTPUT be?
gnipsel.com/mesa/7i96/install.html
Thanks for the help on the spindle section.
JT
JT
- BigJohnT
23 Feb 2022 13:18 #235603
by BigJohnT
JT
And this has been unfixed!Step4+ to 7I96 PWM, Dir4+ to Dir
Also I was wrong about
Thats correct because the PWM sign determines the direction output
JT
- kbec
23 Feb 2022 13:21 #235604
by kbec
I have an appointment to go to but will try later today and let you know how things work out.
Are the settings for the encoder under the spindle tab?
The other issue was my configuration settings are not loading in when I load my file.
- BigJohnT
23 Feb 2022 14:15 #235606
by BigJohnT
Yes the encoder count is on the spindle tab and I think I fixed all the items not getting loaded when you open the ini file.
Thanks for testing and feedback.
JT
JT
- kbec
23 Feb 2022 17:01 #235628
by kbec
The configuration information still isn't coming in when the ini loads for me.
I am also getting the quotes error on the line
I fixed this one, but this is the line:
loadrt [HOSTMOT2](DRIVER) board_ip=[HOSTMOT2](IPADDRESS) config="num_stepgens=[HOSTMOT2](STEPGENS) num_encoders=[HOSTMOT2](ENCODERS) num_pwmgens=[HOSTMOT2](PWMS) "
Also, this setp line keeps having two in it.
setp setp hm2_7i96.0.pwmgen.pwm_frequency [SPINDLE]PWM_FREQUENCY
Here is the surrounding parts, maybe a value is missing and picking up the next line.
setp pid.1.error-previous-target true
setp hm2_7i96.0.pwmgen.00.scale [SPINDLE]SCALE
Also, the line in the io.hal tries to redo something I think is in the hal, unless I comment that out, Linux CNC crashes.
You're more than welcome on the testing and feedback. I wish I knew Python better, but I don't. I'm happy to do what I can to assist.
- BigJohnT
23 Feb 2022 19:24 - 23 Feb 2022 19:25 #235639
by BigJohnT
Post your ini file and the error.
JT
JT
Last edit: 23 Feb 2022 19:25 by BigJohnT.
Time to create page: 0.153 seconds
