Mesa hm2/hm2_7i96s.0: error finishing read
- Thank you received: 5330
20 Jun 2024 21:32 #303447
Replied by PCW on topic Mesa hm2/hm2_7i96s.0: error finishing read
Not sure about the other parts, but:
6.7.12-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.7.12-1 (2024-04-24) x86_64 GNU/Linux.
Is not a real time kernel.
( It needs to say "PREEMPT_RT" )
- Thank you received: 4151
20 Jun 2024 21:39 - 20 Jun 2024 21:39 #303449
Replied by rodw on topic Mesa hm2/hm2_7i96s.0: error finishing read
The method I mentioned includes instructions on how to install the RT kernel too linuxcnc.org/docs/stable/html/getting-st...nate_install_methods
Last edit: 20 Jun 2024 21:39 by rodw.
- vre
- Thank you received: 17
26 Feb 2025 10:41 - 26 Feb 2025 10:42 #322677
by vre
Replied by vre on topic Mesa hm2/hm2_7i96s.0: error finishing read
Mine mesa ethernet card has interrupts on cpu0 how can move it to cpu3 isolated for linuxcnc ?
Last edit: 26 Feb 2025 10:42 by vre.
26 Feb 2025 12:21 #322688
THere is a topic on the forum that explains but I am not logged in to link you to it. Its probably in this thread anyway.
- JT
- Thank you received: 593
26 Feb 2025 14:25 - 26 Feb 2025 14:26 #322703
by JT
Replied by JT on topic Mesa hm2/hm2_7i96s.0: error finishing read
Almost 3 years later and I still have hm2/hm2_7i96s.0:error finishing read!
Grub quiet isolcpus=11 idle=poll r8168.EEE=0 pcie_aspm=off
john@cave:~$ sudo ethtool -i enp6s0
[sudo] password for john:
driver: r8169
version: 6.1.0-29-rt-amd64
firmware-version: rtl8168e-3_0.0.4 03/27/12
expansion-rom-version:
bus-info: 0000:06:00.0
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: yes
supports-priv-flags: no
john@cave:~$ uname -a
Linux cave 6.1.0-29-rt-amd64 #1 SMP PREEMPT_RT Debian 6.1.123-1 (2025-01-02) x86_64 GNU/Linux
The r8168-dkms network driver is installed but ethtool reports the driver as r8169
This package provides the dkms source code for the r8168 kernel modules.
Kernel source or headers are required to compile these modules.
Is the above line from apt my clue?
JT
driver: r8169
supports-test: no
JT
Last edit: 26 Feb 2025 14:26 by JT.
26 Feb 2025 15:01 #322707
You can temporarily check if this helps:
first
chmod +x pinirq.txt
then
sudo ./pinirq.txt [ethernet_device_name_]
Where [ethernet_device_name] is the name of the Ethernet device connected to the 7I96S
(probably eth0, eno1 enp0s25 or similar)
first
chmod +x pinirq.txt
then
26 Feb 2025 15:16 - 26 Feb 2025 15:17 #322710
The problem that is fixed by the DKMS driver has fairly specific symptoms.
can you run:
sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
(will run for ~ 1 minute)
and post the stats here
(assuming 10.10.10.10 card address)
can you run:
Last edit: 26 Feb 2025 15:17 by PCW.
26 Feb 2025 21:58 - 26 Feb 2025 21:59 #322755
dkms builds the drivers from source so you need linux-headers installed for the kernel version you are using. but first you need to
sudo apt purge r8168-dkms
then reboot, then
sudo apt install linux-headers-$(uname -r)
sudo apt install r8168-dkms
then reboot, then
Last edit: 26 Feb 2025 21:59 by rodw.
The following user(s) said Thank You: tivoi
- JT
27 Feb 2025 10:47 #322782
by JT
I ran sudo apt purge r8168-dkms then rebooted now I have no internet connetion on that pc so I can't install anything via apt...
JT
JT
27 Feb 2025 11:48 #322784
It happens, sorry I broke it... sometimes you can log in using another kernel on your system and resolve. I just can't remember how but I have been caught a few times...
Time to create page: 0.157 seconds
