Mesa hm2/hm2_7i96s.0: error finishing read
19 Nov 2023 19:39 - 19 Nov 2023 19:43 #285946 by PCW
Looks like the interface dropped the link entirely...
Does the Yellow LED on the 7I96S RJ45 blink out ever?
Last edit: 19 Nov 2023 19:43 by PCW.
19 Nov 2023 19:42 #285947 by spumco
Replied by spumco on topic Mesa hm2/hm2_7i96s.0: error finishing read
Still thinking it's a setting? Or hardware?
The same behavior repeats every time.
19 Nov 2023 20:05 - 19 Nov 2023 20:16 #285948 by spumco
[7i96 is in back of the machine, so I have to start LCNC and run around to watch...]
Yellow LED stayed lit.
Reds were on (from previous read error?)
Reds went out, green ones blinked sequence then solid
Greens went out, reds lit (assuming when it errored, can't watch screen at same time)
Reds went out again, greens sequenced
Green went out, red lit and stayed lit
EDIT
Sorry, though you meant the yellow board LED.
Yes, the RJ45 yellow LED goes out and them comes back on.
Last edit: 19 Nov 2023 20:16 by spumco. Reason: more info
19 Nov 2023 20:29 #285950 by spumco
Just video'd the sequence.  Sorry if the description is clunky, can't post a vid.
(START)
CR8 - ON
CR7 - off
CR6 - off
CR11-14 - ON
RJ45 Yel - ON
CR8 - ON
CR7 - ON
CR6 - off
CR11-14 - off
RJ45 Yel - off
CR8 - ON
CR7 - off
CR6 - ON
CR11-14 - off
RJ45 Yel - off
CR8 - ON
CR7 - ON
CR6 - off
CR11-14 - off
RJ45 Yel - off
CR8 - ON
CR7 - off
CR6 - off
CR11-14 - off
RJ45 Yel - off
CR8 - ON
CR7 - off
CR6 - off
CR11-14 - sequence then off
RJ45 Yel - off
CR8 - ON
CR7 - off
CR6 - off
CR11-14 - ON
RJ45 Yel - ON
Repeats
19 Nov 2023 21:00 #285955 by PCW
OK I apologize as I was not clear with my red LED comments
If CR7 (/DONE) ever illuminates after power up, there is likely a 5V power issue
(CR6 lighting up after power up indicates a watchdog bite)
19 Nov 2023 22:21 #285961 by spumco
Well...
It appears the 7i96s doesnt like buck converters, but it seems OK with field-expedient cheapo USB wall wart and chopped up USB cable.
It's been running for 10 minutes without a single packet error, much less a read finishing tantrum.
I might have another go with the G2 in a little while.
  • Moderator
  • Moderator
19 Nov 2023 22:28 #285964 by tommylight
Replied by tommylight on topic Mesa hm2/hm2_7i96s.0: error finishing read
Oh good, glad you got this sorted.
19 Nov 2023 23:00 #285967 by spumco
It was only 3 days misery.
Getting the Odroid sorted out last year was 3 or 4 months.
  • Moderator
  • Moderator
19 Nov 2023 23:47 #285976 by tommylight
Hence my insisting on not using any type of SBC for machine control.
I was there once, still have 3 of RPI3 collecting dust. Never again.
20 Nov 2023 02:09 #285982 by spumco
UPDATE
The HP Elitedesk 800 G2 mini has been running Deb 12.2 w/rt6.1. No significant changes to config other than typical intel NIC grub stuff.
No read finishing errors for an hour while running YT in background.
The following user(s) said Thank You: tommylight, Unlogic
Moderators: PCW, jmelson
Time to create page: 0.212 seconds
