Mesa hm2/hm2_7i96s.0: error finishing read
- JT
- Thank you received: 593
27 Feb 2025 15:17 #322793
by JT
JT
Replied by JT on topic Mesa hm2/hm2_7i96s.0: error finishing read
nmcli device show
GENERAL.DEVICE: enp6s0
GENERAL.TYPE: ethernet
GENERAL.HWADDR: F0:2F:74:21:CE:6A
GENERAL.MTU: 1500
GENERAL.STATE: 70 (connecting getting IP configuration)
GENERAL.CONNECTION: Wired connection 1
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/ActiveConnection/5
WIRED-PROPERTIES.CARRIER: on
IP4.GATEWAY: --
IP6.ADDRESS[1]: fe80::9e6b:ff:fe8d:cbd5/64
IP6.GATEWAY: --
IP6.ROUTE[1]: dst = fe80::/64, nh = ::, mt = 1024JT
- vre
- Thank you received: 17
28 Feb 2025 04:40 #322838
by vre
Replied by vre on topic Mesa hm2/hm2_7i96s.0: error finishing read
For 2khz servo thread what max ping must have?
- Thank you received: 5330
28 Feb 2025 05:13 #322840
Replied by PCW on topic Mesa hm2/hm2_7i96s.0: error finishing read
Say 200 uS after 10 minutes or so:
chrt 99 ping -i .0005 -c 600000 -q 10.10.10.10
The following user(s) said Thank You: vre
- Thank you received: 4151
28 Feb 2025 05:14 - 28 Feb 2025 05:15 #322841
Replied by rodw on topic Mesa hm2/hm2_7i96s.0: error finishing read
The answer is always "it depends". In some kernel traces we did, at 1 kHz, the servo thread was done in around 200 usec and it slept for the remaining 800 usec. On a 2 Khz servo thread, it must be done in 500 usec so in theory, the hardware we had would meet the requirements.
Last edit: 28 Feb 2025 05:15 by rodw.
- Thank you received: 7488
28 Feb 2025 13:37 #322868
Replied by tommylight on topic Mesa hm2/hm2_7i96s.0: error finishing read
Some posts just got deleted here????
- JT
28 Feb 2025 18:43 #322880
by JT
I deleted my post because I had the nic set to 10.10.10.10 and the ping times were quite wrong.
JT
JT
28 Feb 2025 20:11 #322884
That is what i was pointing out when the post disappeared on me!I deleted my post because I had the nic set to 10.10.10.10 and the ping times were quite wrong.
JT
- JT
01 Mar 2025 13:24 #322920
by JT
So I've managed to get the PCI NIC working to access the internet and the onboard NIC to communicate with the 7i96S.
The first one is the PCI NIC and the second one the onboard NIC. One thing I noticed is the speed of the onboard NIC is 100Mbit/s even though it's a 2.5 GbE card, is that normal?
JT
john@cave:~$ sudo lshw -C network
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:06:00.0
logical name: enp6s0
version: 06
serial: 68:1c:a2:12:f7:e6
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.1.0-29-rt-amd64 duplex=full firmware=rtl8168e-3_0.0.4 03/27/12 ip=192.168.1.59 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
resources: irq:32 ioport:e000(size=256) memory:e0304000-e0304fff memory:e0300000-e0303fff
*-network
product: RTL8125 2.5GbE Controller
physical id: 0
bus info: pci@0000:09:00.0
logical name: enp9s0
version: 04
serial: f0:2f:74:21:ce:6a
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=6.1.0-29-rt-amd64 duplex=full firmware=rtl8125b-2_0.0.2 07/13/20 ip=10.10.10.12 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
resources: irq:35 ioport:d000(size=256) memory:fcd00000-fcd0ffff memory:fcd10000-fcd13fffThe first one is the PCI NIC and the second one the onboard NIC. One thing I noticed is the speed of the onboard NIC is 100Mbit/s even though it's a 2.5 GbE card, is that normal?
JT
- JT
01 Mar 2025 13:26 #322921
by JT
ping test
JT
john@cave:~$ sudo chrt 99 ping -i .001 -c 60000 -q 10.10.10.10
[sudo] password for john:
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 60095ms
rtt min/avg/max/mdev = 0.048/0.051/4.051/0.021 msJT
- JT
01 Mar 2025 13:54 #322924
by JT
I tried the following grub kernel parameters but the PCI NIC would not work.
I changed my grub kernel parameters to
and did a ping test and my PCI NIC started working again as well
JT
quiet isolcpus=11 idle=poll r8125.EEE=0 pcie_aspm=off
quiet isolcpus=11 idle=poll pcie_aspm=offI changed my grub kernel parameters to
quiet isolcpus=11 idle=polland did a ping test and my PCI NIC started working again as well
60000 packets transmitted, 60000 received, 0% packet loss, time 60092ms
rtt min/avg/max/mdev = 0.049/0.051/0.123/0.001 msJT
Time to create page: 0.189 seconds
