Mesa 5i24-25 stucked
- yrsiddhapura
- Thank you received: 5
21 Sep 2022 07:10 #252481
by yrsiddhapura
Replied by yrsiddhapura on topic Mesa 5i24-25 stucked
libpci-dev and libmd-dev are not istalling
cnc@debian:~/Desktop$ sudo apt-get install libpci-dev libmd-dev pkg-config build-essential git
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package libpci-dev
E: Unable to locate package libmd-dev
- yrsiddhapura
21 Sep 2022 10:20 - 21 Sep 2022 10:28 #252494
by yrsiddhapura
I have successfully flashed firmware you given but while I give command sudo mesaflash --device 5i24 --dbname1 7i52S --dbname2 7i52 --readhmid it returns error saying dbname1 is unrecognised option
Note:
I was not able to install mesaflash 3.4 on wheezy so i install Linuxcnc 2.8 buster image and try to flashed and it worked. Do I still need to install mesaflash 3.4 or what command would giver version details
Note:
Last edit: 21 Sep 2022 10:28 by yrsiddhapura.
- yrsiddhapura
21 Sep 2022 11:58 #252499
by yrsiddhapura
@PCW
Hey its worked with mesaflash 3.4.3 i could read all pinouts
- yrsiddhapura
21 Sep 2022 12:44 - 21 Sep 2022 12:50 #252502
by yrsiddhapura
Here is a bitfile for a 5I24-25 with a 7I52S and a 7I52
You should be able to get the pinout with
using this firmware and command i am getting this output:
P2-5,6:/Ena 0 IOPort None
P5-1,2,9,10 1 IOPort MuxedQCount 0 MuxQ-A (In)
P5-4,5,12,13 2 IOPort MuxedQCount 0 MuxQ-B (In)
P5-7,8,15,16 3 IOPort MuxedQCount 0 MuxQ-IDX (In)
P5-17,18,P4-1,2 4 IOPort MuxedQCount 1 MuxQ-A (In)
P5-20,21,P4-4,5 5 IOPort MuxedQCount 1 MuxQ-B (In)
P5-23,24,P4-7,8 6 IOPort MuxedQCount 1 MuxQ-IDX (In)
P3-9,10,17,18 7 IOPort MuxedQCount 2 MuxQ-A (In)
P3-12,13,20,21 8 IOPort MuxedQCount 2 MuxQ-B (In)
P3-15,16,23,24 9 IOPort MuxedQCount 2 MuxQ-IDX (In)
Internal-EncMux 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
P2-21,22 11 IOPort StepGen 5 Step/Table1 (Out)
P2-19,20 12 IOPort StepGen 5 Dir/Table2 (Out)
P2-13,14 13 IOPort StepGen 4 Step/Table1 (Out)
P2-11,12 14 IOPort StepGen 4 Dir/Table2 (Out)
P2-5,6 15 IOPort StepGen 3 Step/Table1 (Out)
P2-3,4 16 IOPort StepGen 3 Dir/Table2 (Out)
IO Connections for P3 -> 7I52
Pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
P2-5,6:/Ena 17 IOPort StepGen 2 Step/Table1 (Out)
P5-1,2,9,10 18 IOPort StepGen 2 Dir/Table2 (Out)
P5-4,5,12,13 19 IOPort StepGen 1 Step/Table1 (Out)
P5-7,8,15,16 20 IOPort StepGen 1 Dir/Table2 (Out)
P5-17,18,P4-1,2 21 IOPort StepGen 0 Step/Table1 (Out)
P5-20,21,P4-4,5 22 IOPort StepGen 0 Dir/Table2 (Out)
P5-23,24,P4-7,8 23 IOPort None
P3-9,10,17,18 24 IOPort SSerial 0 TXEn3 (Out)
P3-12,13,20,21 25 IOPort MuxedQCount 3 MuxQ-A (In)
P3-15,16,23,24 26 IOPort MuxedQCount 3 MuxQ-B (In)
Internal-EncMux 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
P2-21,22 28 IOPort MuxedQCount 4 MuxQ-A (In)
P2-19,20 29 IOPort MuxedQCount 4 MuxQ-B (In)
P2-13,14 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
P2-11,12 31 IOPort MuxedQCount 5 MuxQ-A (In)
P2-5,6 32 IOPort MuxedQCount 5 MuxQ-B (In)
P2-3,4 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
IO Connections for P2
DB25 pin# I/O Pri. func Sec. func Chan Sec. Pin func Sec. Pin Dir
1 34 IOPort MuxedQCountSel 6 MuxSel0 (Out)
14 35 IOPort SSerial 0 TXData5 (Out)
2 36 IOPort SSerial 0 RXData5 (In)
15 37 IOPort SSerial 0 TXData4 (Out)
3 38 IOPort SSerial 0 RXData4 (In)
16 39 IOPort SSerial 0 TXData3 (Out)
4 40 IOPort SSerial 0 RXData3 (In)
17 41 IOPort SSerial 0 TXData2 (Out)
5 42 IOPort SSerial 0 RXData2 (In)
6 43 IOPort SSerial 0 TXData1 (Out)
7 44 IOPort SSerial 0 RXData1 (In)
8 45 IOPort SSerial 0 TXData0 (Out)
9 46 IOPort SSerial 0 RXData0 (In)
10 47 IOPort SSerial 0 TXEn0 (Out)
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
it seems i am getting almost double encoder input on 7i52s and half of step/dir and on 7i52 same double encoder and only single sserial abd its also said DB25 pin while boards are 50pins is any firmware which gives 12 channel differential output (6 step/dir) + 6 channel encoder on 7i52s and 6 Channel encoder 6 channel Serial RS-422 on 7i52
Last edit: 21 Sep 2022 12:50 by yrsiddhapura.
- Thank you received: 5330
21 Sep 2022 13:34 #252506
Replied by PCW on topic Mesa 5i24-25 stucked
That firmware is correct, It must be a Mesaflash error.
Does mesaflash show all 24 pins per connector if you don't use the --dbname option?
- yrsiddhapura
21 Sep 2022 13:58 #252509
by yrsiddhapura
Ok got it to utilize 7i52s and 7i52 board at fully functionality i have to wire it to connect all 3 connector at 5i24-25
- yrsiddhapura
21 Sep 2022 14:30 #252511
by yrsiddhapura
no its shows only 17 pin per connector:
lcnc@lcnc:~$ sudo mesaflash --device 5i24 --readhmid
[sudo] password for lcnc:
Configuration Name: HOSTMOT2
BoardName : MESA5I24
FPGA Size: 25 KGates
FPGA Pins: 256
Number of IO Ports: 3
Width of one I/O port: 24
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: DPLL
There are 1 of DPLL in configuration
Version: 0
Registers: 7
BaseAddress: 7000
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
There are 3 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 4
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: StepGen
There are 6 of StepGen in configuration
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P4
1 0 IOPort None
14 1 IOPort MuxedQCount 0 MuxQ-A (In)
2 2 IOPort MuxedQCount 0 MuxQ-B (In)
15 3 IOPort MuxedQCount 0 MuxQ-IDX (In)
3 4 IOPort MuxedQCount 1 MuxQ-A (In)
16 5 IOPort MuxedQCount 1 MuxQ-B (In)
4 6 IOPort MuxedQCount 1 MuxQ-IDX (In)
17 7 IOPort MuxedQCount 2 MuxQ-A (In)
5 8 IOPort MuxedQCount 2 MuxQ-B (In)
6 9 IOPort MuxedQCount 2 MuxQ-IDX (In)
7 10 IOPort MuxedQCountSel 0 MuxSel0 (Out)
8 11 IOPort StepGen 5 Step/Table1 (Out)
9 12 IOPort StepGen 5 Dir/Table2 (Out)
10 13 IOPort StepGen 4 Step/Table1 (Out)
11 14 IOPort StepGen 4 Dir/Table2 (Out)
12 15 IOPort StepGen 3 Step/Table1 (Out)
13 16 IOPort StepGen 3 Dir/Table2 (Out)
1 17 IOPort StepGen 2 Step/Table1 (Out)
14 18 IOPort StepGen 2 Dir/Table2 (Out)
2 19 IOPort StepGen 1 Step/Table1 (Out)
15 20 IOPort StepGen 1 Dir/Table2 (Out)
3 21 IOPort StepGen 0 Step/Table1 (Out)
16 22 IOPort StepGen 0 Dir/Table2 (Out)
4 23 IOPort None
17 24 IOPort SSerial 0 TXEn3 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
FPGA Pins: 256
IDROM Type: 3
Module: DPLL
Version: 0
Registers: 7
BaseAddress: 7000
Module: WatchDog
Version: 0
Registers: 3
BaseAddress: 0C00
Module: IOPort
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
Version: 4
Registers: 5
BaseAddress: 3600
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
Version: 0
Registers: 6
BaseAddress: 5B00
Module: StepGen
Version: 2
Registers: 10
BaseAddress: 2000
Module: LED
Version: 0
Registers: 1
BaseAddress: 0200
1 0 IOPort None
4 23 IOPort None
11 48 IOPort None
12 49 IOPort None
13 50 IOPort None
21 Sep 2022 14:37 #252513
Strange, I'll see if I can duplicate that here.
I don't see that in the Mesaflash code, but will take a closer look.
The following user(s) said Thank You: yrsiddhapura
- yrsiddhapura
21 Sep 2022 14:58 #252515
by yrsiddhapura
ya sure but i have lil urgent to complete mine project.
22 Sep 2022 01:07 - 22 Sep 2022 01:07 #252544
The Mesaflash --readhmid bug should be fixed (version 3.4.4)
Last edit: 22 Sep 2022 01:07 by PCW.
Time to create page: 0.774 seconds
