- Thank you received: 426
Old mate is right, it'll work fine using the standard SPI pinout on the RPi4 (don't try a Rpi5). I've played around with this board a bit using SPI, EPP and with modded SSerial code and used it as a smart serial device.
I found the best way to achieve 3.3v to 5v translation is to replace all the buffers on the non commoned lines with SN74CBT3245 and power the board with 4.2v. Tho on the "outside world side" the signal will need pulling up to 5v via a resistor.
And those reasons would be ?
Based on what ideas ?
