Mori MVJR Build Log
- schmidtmotorworks
- Thank you received: 6
I have power to the servos now with one axis motor disconnected from the screw for testing.
I tried the manual jog in AXIS and the motor turned about 1/2 turn then started vibrating.
(I have to admit it was exciting to see something move on that machine!)
From reading the following in PID tuning, I guess this means the P is too high or I should increase I next.
'"Simple method
If the system must remain on line, one tuning method is to first set the I and D values to zero. Increase the P until the output of the loop oscillates. Then increase I until oscillation stops. Finally, increase D until the loop is acceptably quick to reach its reference. A fast PID loop tuning usually overshoots slightly to reach the set point more quickly; however, some systems cannot accept overshoot."
I am not clear what "increase P until the output of the loop oscillates" means.
Does it mean the same as the drive motor vibrating?
If so, does it mean that it would:
1. Start to osculate just from increasing the P without jogging it?
2. Start to osculate just from increasing the P after jogging it?
3. Something else?
I guess the next thing to do is start tuning the rest of INI file.
The default value DEADBAND in my INI = 0.000015; I don't know what resolution my encoder has but I would be surprised to hear that it was that close, maybe that number should be more like 0.0002"?
Here is what I have now, if anyone sees something out of line can you set me straight?
[TRAJ]
AXES = 3
# COORDINATES = X Y Z
COORDINATES = X Y Z
# HOME = 0 0 0 0
HOME = 0 0 0
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 1.00
MAX_VELOCITY = 6.567
DEFAULT_ACCELERATION = 6.0
MAX_ACCELERATION = 10.0
[AXIS_0]
TYPE = LINEAR
BACKLASH = 0.000
FERROR = .5
MIN_FERROR = .5
INPUT_SCALE = -25400
# PID tuning params
DEADBAND = 0.000015
P = 10
I = 0
D = 0
FF0 = 0
FF1 = 0
FF2 = 0
BIAS = 0
- BigJohnT
- Thank you received: 1176
3. Something else?
I'd start with a P = 1
The oscillates is when the PID is trying to hold the position but it keeps overshooting due to too much P for the rest of the settings. Having said that you won't be able to tune the servos without the full load on the motor. It is a good idea to make sure your in control of the the motor before tuning the axis. I would increase the P in small increments or it might get wild (wonder how I know) and exciting. I would venture to guess that the vibration is really motor oscillation trying to hold position but overshooting on each attempt.
Have you seen the wonderful and clear explanations on PID and FFn on this forum?
- schmidtmotorworks
I removed my drive motor thinking I would need to adjust the speed first.
But now I find this osculation problem shows up first.
So what should I do first?
Reconnect the motor to tune PID, or get it roughed-in while it is disconnected first?
I'm not sure, I found some reading, but don't feel confident that I know what I am doing.
- Thank you received: 5271
You also may need to tune the drives velocity loop (outside of EMC, for older drives this may be a potentiometer adjustment)
- BigJohnT
Hmmmm, maybe my procedure is off then.
Read this.
www.linuxcnc.org/component/option,com_ku...,14483/lang,english/
and like Peter said you can't tune the bare motor as the reactions will be very different and you will find that you have wasted a bunch of time, unless of course your learning how to use HalScope or making sure your e-stop circuit is near by and functioning properly... I might do those with the bare motor.
John (who is a rank beginner when it comes to servo tuning and has only done it 3 times)
- schmidtmotorworks
- schmidtmotorworks
- BigJohnT
- Thank you received: 4994
As has been said, it is very difficult to tune PID with a bare motor. However, it is a good idea to start with a bare motor to make sure that it isn't going to run away (the fact that the motor stopped indicates that the encoder and controller agree about which way is clockwise, which is a very good start.)I have power to the servos now with one axis motor disconnected from the screw for testing.
I have forgotten what sort of motor you have, but if they are brushless then it might be worth commenting out the PID from the HAL and making sure that you can spin the bare motor smoothly at variable speeds with setp commands from the command line or in the machine->show hal config window.
Whilst you can't tunr you PID loop properly for the machine, you might be able to tune the bare motor with a very low P and I terms, but the numbers you come up with will be entirely wrong for when the machine is re-connected. Don't get too worried if you can't actually tune the bare motor.
However, what you have done so far is not a waste of time because you now know that the motor isn't going to run away.
- schmidtmotorworks
With P set to 1, I was able to send
"unlinkp hm2_5i23.0.pwmgen.00.value"
"setp hm2_5i23.0.pwmgen.00.value .1"
the motor ran smoothly
I stepped it up to:
"setp hm2_5i23.0.pwmgen.00.value .5"
It still runs smooth but a little more than twice as fast as i expected so I will probably start adjusting the pots tonight. Is it correct to do this before PID have been established, or will I need to come back and do that again later?
I thought I had read an explanation of a procedure to adjust PID using halscope but I can't find it now.
Does anyone know of a doc on that?
