Roland mdx-650a question
07 Nov 2014 03:22 #52892 by ducatidragon916
Replied by ducatidragon916 on topic Roland mdx-650a question
is the MDX 540 the same board as well as the MDX 500? as you said the 650 is the same as the 500 just wondering as i have possible access to a 540 board.. any ideas?
07 Nov 2014 03:35 #52893 by nick gill
Replied by nick gill on topic Roland mdx-650a question
No, the 540 is different to the 500/650.
The 540 does use the same horrible spindle motor, but the main board is different. I'm not sure what other similarities there are.
A guy contacted me with a MDX-40 spindle motor stator that uses the same hall effect sensors as ours use. His were all burned. Check yours.
07 Nov 2014 03:50 #52894 by ducatidragon916
mine is fine
07 Nov 2014 06:47 #52896 by ducatidragon916
okay I found a descrepancy on the motherboard....section for x servo the driver transistors all show 24V on the collectors on both left and right sides of the board, on the Y servo drive transistors on collectors on one side shows 24 but on the other side shows 13-14 volt not the same perhaps this is shwing me that maybe the drivers are bad!!?? I am going to look at the schematic again and see hw they are ocnifgured and if this is the case ot could possibly why it is failing before it gets to the z axis home etc.....
07 Nov 2014 08:16 #52897 by nick gill
Yeah possibly.
The supply is from a 24v tap on the transformer. If something has failed short it could pull the voltage down. Transistors are cheap. Maybe buy a bunch and try substituting them.
07 Nov 2014 15:52 #52904 by ducatidragon916
do you have yours up and running? if so could you check to see if it is suppose to be 24v on all sides of the diodes or 14v one side and 24 on the other etc?
08 Nov 2014 01:58 #52925 by nick gill
PM sent
08 Nov 2014 04:59 #52928 by ducatidragon916
PM- personal message? not sure is that a function on this forum? etc or another location ?
08 Nov 2014 05:00 #52929 by ducatidragon916
Pm here?
08 Nov 2014 05:10 #52930 by nick gill
Sorry. I went to your profile messages>send email and gave you my email address to send some photos to.
Cheers.
Time to create page: 0.721 seconds
