Light Machine Corp. Benchman XTr (retrofit)
9 years 4 months ago #94867 by genixia
Thanks, knowing how the brake is supposed to work goes a *long* way to helping me fix it!
It doesn't shock me to hear that the way covers were pricey. It seems that everything on this machine was designed with quality as its underlying ethos. I'll reach out to LMC, but I suspect that I'll end up doing the top-bottom swap. They look identical and common sense suggests they should be. I'll find out in due time.
Great call on the oil sludge potential. That spindle rebuild would be an expensive mistake to make. It might be a non-issue anyway - it pumps fine without pump errors, and shouldn't be evaporating. It looks a little lower in the sump then I'd expect, so I'll look more into that.
9 years 4 months ago #94868 by x-Intelitek Engineer
The coolant is a water-based coolant. The key is to make sure you use distilled water mixed with the coolant. LMC should be able to tell you exactly what it is.
The pump should essentially be a closed system. The only place for evaporation would be caps that are not tight and/or leaks.
9 years 4 months ago #95094 by genixia
So that nut was indeed loose. A few minutes with an allen key solved that problem, the z-axis is now locked. I suppose I should ensure that the brake disengages when 24V is applied before I go too much further there.
I can also confirm that the z-axis way covers are identical. The bottom one was a mess, chips on both sides. No evidence of chips on the ballscrew or rails though. Once I gave it a good clean with kero and an old toothbrush and removed the chip build-up from the inside of the folds, it concertinaed much better, although still not as good as the top cover, so i am swapping them.
I also found what might by evidence of a crash. Low on the front face of the left z-axis rail is what looks like a small gouge from a cutter. Both the running edges of the rail appear perfect, so I'll take a stone to that gouge just to ensure that it won't foul the carriage. The gouge corresponds to an aberration on the way cover. How a cutter gouged the rail without actually puncturing the cover is beyond me. I know that prior to rebuild the spindle suffered from high G vibrations, and crashes are a major cause of ceramic bearing failure, so it wouldn't surprise me.
That spindle rebuild could also explain the minor coolant loss. I'll extract a few cc from the chiller and confirm that it mixes with distilled water ok. The chiller only holds 2G, and can't be more than a pint or so low. I'll likely just top it with distilled water. Water soluble coolant is likely glycol based for both its anti-corrosion and anti-freeze properties, and should be tolerant of a few percent dilution.
9 years 4 months ago #95107 by cncamateur
Hello All,
I have a 2002 benchman XT that I cant get running. As it stands now I get the sw running and a door lock error. The Intellitek SW seems to see the ATC and nextmove cards (I have two nextmove cards (PCI001-504) one errors (4 red leds, sw errors) the other seems to work, ATC errors when serial cable disconnected, but not when connected). I suspect I will see other troubles but I cant get past the door lock. The control card in the back of the unit is part number 22-8200-0054, I cant read the model or serial of the whole unit. my questions are:
1. is there an easy way to bypass the door lock, maybe using tp 30 and 31?
2. My machine has the 4th axis but its bypassed in bench-setup and also has the plug on the connector. There are two cablea coming out of the benchman that both fit the nexmove card, is the one connected to J18 on the board in the back of the unit the correct one for operation without a 4th axis? (this seems to be the 100 pin one)
3. Is there anything else I should look at to get it going, or a way to test the Nextmove card? Nothing seems to work unless I can home it, and it wont move without door lock. Spindle doesn't run. I have the manuals and the readme with the PCI card update, I have attached a photo of the rear wiring box.
9 years 4 months ago #95112 by x-Intelitek Engineer
Is your door lock error an indication in the s/w that the door is/is not locked or is your door always physically locked?
Due to safety concerns, I cannot advise you how to bypass the door lock or it's signals but it is a simple circuit.
I can't post the entire board schematic without Intelitek's permission, but I have attached the relevant Door Lock section.
J18 is the main Nextmove connection.
J18-86 is the signal from Nextmove to lock the door
J18-44 is the signal to Nextmove that the door is locked
J18-93 is the signal to Nextmove that the door is open
The software won't allow movement or spindle while errors are present.
You need to get that red box in the lower right off.
Let me know if I can help in any other way.
Don
9 years 4 months ago #95113 by x-Intelitek Engineer
I meant to add this drawing to the last post.
It is the "block diagram" on which the machine is based.
I created it during development of the machine, but it may not be 100% accurate to what is present in your machine.
Regards
Don
Time to create page: 0.119 seconds
