But just think how much you are learning about HAL debugging.mblaszkiewicz wrote: Ok back home and debugging again
and another error
mblaszkiewicz wrote: Started checking the machine and I have a reading error in the x axis so far. moved 3 inches (by program) and checked with a size block (+-.0002) and had to move another .050. So from 1 side of the block to the other it was 3.050 reading from the Computer. Is it an encoder issue or ball screw error comp.
