Brother TC-211
12 years 1 month ago #51256 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
Debug file information:
Brother_TC-211.hal:245: Pin 'orient-pos' does not exist
4320
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
net spindle orient-pos orient.0.command => pid.spindle.command
Ok I have no idea at all :(
12 years 1 month ago #51257 by mblaszkiewicz
This is what happens when I try to write a HAL file without a LinuxCNC machine to test it on. (though without a 7i77 I could never have tested this file).
You can fly over anytime you want and play away :) :) :) :) :) :)
12 years 1 month ago #51260 by andypugh
Replied by andypugh on topic Brother TC-211
mblaszkiewicz wrote: Brother_TC-211.hal:245: Pin 'orient-pos' does not exist
Sorry, it was 2am last night, I had to log out.
I can see why that one is hard to decode. The problem is another typo.
The format of a "net" command is
net signal pin pin pin pin....
Unfortunately I put a space instead of a hyphen in the signal name, so the net command is creating a signal called "spindle" then trying to connect a pin called "orient-pos" to it.
The line needs to be
net spindle-orient-pos orient.0.command => pid.spindle.command
12 years 1 month ago #51268 by mblaszkiewicz
I will do that change tonight. At work now. Again thanks so much for the help.
On a side question what kind of bike do you ride. (Your avatar)
12 years 1 month ago #51269 by andypugh
mblaszkiewicz wrote: On a side question what kind of bike do you ride. (Your avatar)
Depending on the day, or the reason, either a 2004 Yamaha R1, a 2003 GasGasEC200 or a 1921 Ner-a-Car Model A.
12 years 1 month ago #51287 by mblaszkiewicz
Ok back home and debugging again
and another error :(
Brother_TC-211.hal:246: Pin 'hm2_5i25.0.7i77.0.1.encoder.03.position' does not exist
4803
and line 246
net spindle-orient-fb hm2_5i25.0.7i77.0.1.encoder.03.position => orient.0.position
no idea on the fix
Time to create page: 0.448 seconds
