Brother TC-211
12 years 1 month ago #50940 by Zahnrad Kopf
Replied by Zahnrad Kopf on topic Brother TC-211
andypugh wrote: Normally the brakes seem to be sprung "on" so that with no power the axis is locked, and it is actively unlocked when the motor is powered up and ready to use it.
That's standard. It's that way so that if power goes out, you don't have your head falling and crashing into the table. :ohmy:
12 years 1 month ago - 12 years 1 month ago #50969 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
Ok I'm a little lost again.
Here is my z axis hal
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
net z-index-enable <=> pid.z.index-enable
net z-enable => pid.z.enable
net z-output => pid.z.output
net z-pos-cmd => pid.z.command
net z-vel-fb => pid.z.feedback-deriv
net z-pos-fb => pid.z.feedback
# ---PWM Generator signals/setup---
setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [AXIS_2]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout0-minlim [AXIS_2]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [AXIS_2]OUTPUT_MAX_LIMIT
net z-output => hm2_5i25.0.7i77.0.1.analogout0
net z-pos-cmd axis.2.motor-pos-cmd
net z-enable axis.2.amp-enable-out
setp hm2_5i25.0.encoder.00.counter-mode 0
setp hm2_5i25.0.encoder.00.filter 1
setp hm2_5i25.0.encoder.00.index-invert 0
setp hm2_5i25.0.encoder.00.index-mask 0
setp hm2_5i25.0.encoder.00.index-mask-invert 0
setp hm2_5i25.0.encoder.00.scale [AXIS_2]ENCODER_SCALE
net z-pos-fb <= hm2_5i25.0.encoder.00.position
net z-vel-fb <= hm2_5i25.0.encoder.00.velocity
net z-pos-fb => axis.2.motor-pos-fb
net z-index-enable axis.2.index-enable <=> hm2_5i25.0.encoder.00.index-enable
net z-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
# ---setup home / limit switch signals---
net home-z => axis.2.home-sw-in
net min-z => axis.2.neg-lim-sw-in
net max-z => axis.2.pos-lim-sw-in
And how it is wired off of the servo driver to the 7i77 board
CN8-10 A TB3-1
CN8-9 /A TB3-2
CN8-12 B TB3-4
CN8-11 /B TB3-5
CN8-17 Z TB3-7
CN8-13 /Z TB3-8
ANALOG VELOCITY COMMAND
CN8-1 AOUT TB5-4
CN8-2 GND TB5-3
DRIVE ENABLE
CN8-15 ENA+ TB5-2
CN8-16 ENA- TB5-1
So adding the line of code from before
net zenable hm2_5i25.0.7i77.0.output-03
output 3 would actualy be output 2 ?????
and where would I wire the relay connections to on the 7i77 board ????
Would that be tb8 pin 20 for output 3
I'm really lost here
Mesa pdf for 7i77
image missing http://i1357.photobucket.com/albums/q757/mblaszkiewicz/Screenshot-EWPD7i77manwpd_zpsca4966fc.png
Last edit: 12 years 1 month ago by mblaszkiewicz.
12 years 1 month ago #50972 by cncbasher
Replied by cncbasher on topic Brother TC-211
yes output pin 3 is pin 20 on TB8 , the confusion is that the pins start at 0 and not 1
so yes it can be confusing at first
2 have 2 banks of inputs and outputs on tb8 and tb 7
the first 16 pins are inputs and the last 8 are outputs
so your relay ( 24v) would go from your 24v + to the 7i77 TB8 PIN 20
and that your field voltage is is 24v TB2 pin 1 and ground pin 8
12 years 1 month ago #50973 by andypugh
Replied by andypugh on topic Brother TC-211
mblaszkiewicz wrote: net z-enable => pid.z.enable
Firstly, in your HAL file the Z axis enable signal is called "z-enable" with a hyphen, so use that in any extra code you add.
Note that you can add the brake stuff in the custom.hal file if you want to leave the main HAL file as-generated.
All HAL files share the same "name space", ie the same pin names and signal names are available to all HAL files.
DRIVE ENABLE
CN8-15 ENA+ TB5-2
CN8-16 ENA- TB5-1
You could possibly connect the brake relay here, but then you don't get to add the timedelay, so it is probably better not to.
I chose output-03 _completely_ at random. You should use whichever output is convenient for you.
I got the pin naming convention a little bit wrong, now that I look around the web for examples.
If we stick with output 03, then according to the Mesa manual that is on TB8 pin 20.
I will get back to this later with a wiring schematic.
12 years 1 month ago - 12 years 1 month ago #50974 by andypugh
Diagram Attached
Last edit: 12 years 1 month ago by andypugh.
12 years 1 month ago #51153 by mblaszkiewicz
Thanks Andy the machine now has a brake on the Z axis. :)
Next thing on the list of to do. Anyone have any idea on how to orient the spindle.
The spindle is actually a very large servo and does have a resolver that outputs to encoder signals.
I beleive its wired the same way as the other axis's and I wired it that way into the 7i77 card.
Also the machine homes very slowly. Any ideas on that would be great also.
Time to create page: 0.363 seconds
