Brother TC-211
12 years 1 month ago - 12 years 1 month ago #50788 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
Ok picture time and some ramblings
image missing http://i1357.photobucket.com/albums/q757/mblaszkiewicz/20140904_183741_zpsf2dd34ca.jpg
in this page of the book the z axis brake is defined as RY16 BMR- Z-axis brake
image missing http://i1357.photobucket.com/albums/q757/mblaszkiewicz/20140904_183451_zps2bc3b1e1.jpg
On this page pin 139 and 140 are internal use 24v and listed as BMR
could this be the pin out for the brake ??????
image missing http://i1357.photobucket.com/albums/q757/mblaszkiewicz/20140904_183335_zps5cf5e8f4.jpg
This is the top of the z axis where the servo motor is mounted
image missing http://i1357.photobucket.com/albums/q757/mblaszkiewicz/20140904_183303_zps75fe3205.jpg
sorry blurry but you can see the coupling on top and the wires leading into the brake (I hope)
Last edit: 12 years 1 month ago by mblaszkiewicz.
12 years 1 month ago #50856 by mblaszkiewicz
Amy input from the linux master's here does my idea on the wires sounds right and or does that look like the z axis brake
12 years 1 month ago #50858 by cncbasher
Replied by cncbasher on topic Brother TC-211
yes thats the brake , so make it that a relay puts 24v across the coil when the z axis is disabled , easiest way is to have the relay on the amplifier enable for z axis
and wire so the z amplifier is enabled and the brake is disabled , using a 2 pole changeover relay , so they cant both be on at the same time , so on an energised relay the brake is powered ( across the normaly closed contacts ) on i pole , and the amplifier enable on the other pole but using the normaly open , then you only need to worry over 1 enable line and the brake will look after it's self , if you get my meaning
12 years 1 month ago #50861 by mblaszkiewicz
Ok read through your advise and a little lost
also had my electronics specialist/consultant read it
image missing http://i1357.photobucket.com/albums/q757/mblaszkiewicz/smartoreo_zps523d4375.jpg
and both of us are lost. A simple diagram would be great if possible.
(And everyone is wondering why this is taking me so long :laugh: )
12 years 1 month ago #50864 by mblaszkiewicz
Also checked pin 139 - 140 . They are the wires that control the brake thru the onboard relays. How would I wire them in to prevent the z axis from dropping.
12 years 1 month ago - 12 years 1 month ago #50901 by mblaszkiewicz
Is there anyway to right the z brake into the hal or ladder something like
if z is active power 24v
if z is not active no power
Using what I have readily avaliable on z servo I don't have 24 volts to wire the brake into
Time to create page: 1.919 seconds
