Brother TC-211
12 years 2 months ago #50167 by Zahnrad Kopf
Replied by Zahnrad Kopf on topic Brother TC-211
mblaszkiewicz wrote: Wired up wrong :(
Don't beat yourself up too badly... You'll get to watch, point, smile, and giggle when you hear me describe the same things shortly... Glad you got it figured out.
12 years 2 months ago - 12 years 2 months ago #50183 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
I'm lucky enough to have a manual for the machine. I just wish they put ask relevant info in the same area's not spread out all over. Are you working in a brother also. If so I'll take some better pics and send them to you and include the wiring I needed to get Mine ruNning in detail.
Last edit: 12 years 2 months ago by mblaszkiewicz.
12 years 2 months ago #50198 by Zahnrad Kopf
mblaszkiewicz wrote: I'm lucky enough to have a manual for the machine. I just wish they put ask relevant info in the same area's not spread out all over. Are you working in a brother also. If so I'll take some better pics and send them to you and include the wiring I needed to get Mine ruNning in detail.
No, no... I am working on an Emco turning center. But I'm very ignorant and likely more bull-headed to boot, so will no doubt be bashing into things while trying to finish it up... ( as most of my recent threads will confirm )
12 years 2 months ago #50227 by mblaszkiewicz
Ok everything is wired correctly and working. All the limit switches are active.
I still have a little run away and joint following error on the x axis.
Anyone have any ideas. also may need to be talked through tuning the servo's
Thanks again to everyone for their help
12 years 2 months ago #50235 by PCW
Replied by PCW on topic Brother TC-211
Does the x axis follow jogging or does it runaway as soon as you jog?
(having a little runaway is like being a little bit pregnant you either have runaway or you dont)
runaway means that the feedback is backwards so you have no control of motion at all
once you have control of all axis (even with large following errors) you can begin tuning
gnipsel.com/linuxcnc/tuning/servo.html
12 years 2 months ago #50238 by mblaszkiewicz
As soon as I take the e stop off and hit the machine button it moves the x Axis. The y axis and z are OK. I am wondering if changing the x axis to inverted may have some thing to do with it.
Time to create page: 0.070 seconds
