Brother TC-211
- mblaszkiewicz
- Thank you received: 4
13 Aug 2014 04:24 #49780
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
When I start linuxcnc I can manually move all the axis one at a time. If I set the position to projected ?? (I think) it will show movement. When I have it as actual nothing moves at all in the read out, even though the axis is moving.
And shipping wars. its a show on discovery. Jared breaks almost everything he touches, or is really really late.
13 Aug 2014 04:33 #49781
I still don't understand what you are describing.
Does the actual, physical, machine move?
If the machine moves and the "actual" position in LinuxCNC doesn't move then that means that the position feedback isn't getting through from the encoders to motion controller in the software.
This might actually just be a HAL problem.
Replied by andypugh on topic Brother TC-211
- scubasteve1
13 Aug 2014 05:17 #49783
by scubasteve1
Replied by scubasteve1 on topic Brother TC-211
Sounds like the Linux side (not a drive, or mechanical) issue, like the Z axis is not being seen as a "real" axis. If one just installs and configures LinuxCNC they can jog axis's and see numbers move on the monitor.....
Ran into something like this Monday on a Citizen machine. I forgot I had the Z2 axis turned off after taking out the servo for repair. Put the motor in, tried zero-returning, and there was no physical axis movement but the control showed movement and did not care about real feedback... Granted that is a Mitsubishi control but the principle still applies.
Where is the Z axis physically? Have you worked with any ATC stuff, or are you going to do this manually?
Have you tried sending an "enable" signal to the Z-axis manually?
Where are you at currently with this? I do quite a bit of CNC service work and am familiar with Brother stuff (very easy to work with). If your really really stuck, shoot me a PM or email
FYI you will prob never get better results with a half-arse CNC machine than a real one, not to mention a brother. This is just a small hump to get over.
- Zahnrad Kopf
13 Aug 2014 05:29 #49784
by Zahnrad Kopf
Ah. That explains it. Television reference. I don't watch very much television.
Just the news, PBS ev'ry once in a while, and maybe an odd blue moon gander at something else from one of the educational show.
Replied by Zahnrad Kopf on topic Brother TC-211
- mblaszkiewicz
13 Aug 2014 06:07 #49786
by mblaszkiewicz
scuba steve, I'm in ct. If you are willing to do a weekend service call I would be willing to pay for your time and travel. The machine works fine with the brother controller. Only thing is that I need it to read g-code. Its a 1986 machine and 100 percent conversational, hence the transfere to linux. Just send me an email at This email address is being protected from spambots. You need JavaScript enabled to view it. and I would be willing to discuss payment if you are able to do the job.
or call me at 860 924-6374
- scubasteve1
13 Aug 2014 06:20 #49787
by scubasteve1
Just gave you a ring, no answer
I'm in the midwest.... and not in a position to do a trans-continental service call for something I cannot garuntee... but phone help is free! Or very close to free
I'm vaguely familiar with that vintage brother and controls. Can you re-post the servo drive make and model, and a copy of all your settings on the Linux-side of things?
- mblaszkiewicz
13 Aug 2014 07:00 #49789
by mblaszkiewicz
Sorry Steve phone died. I will call you tomorrow
For anyone else. I have motion on the table. I can move it in x y and z. I can turn the spindle on. In manual mode and commanded position the dro show position Movement. In actual position the dro stays at zero.
13 Aug 2014 15:46 #49796
That sounds very odd. It also sounds like a very minor problem which should be easy to fix.
Do you get a following error eventually? (what are your f-error limits?)
What this ought to mean is that the encoder feedback is getting back to the PID components, but not back to the motion controller.
If you look in Halshow (Machine, show HAL configuration) what is shown linked to the axis.N.motor-pos-fb pins?
- mblaszkiewicz
14 Aug 2014 03:43 #49830
by mblaszkiewicz
I found the axis lines. What do you mean linked to it. I have
9. Float. In. 0.axis.0.motor-pos-fb (an arrow)
X-pos-fb
X-pos-fb
14 Aug 2014 04:00 #49831
Does X-pos-fb (spelt exactly like that) appear anywhere else in the HAL file.
I suspect that the encoder is linked to a different signal (X-pos-fb is the "signal")
X-pos-fb
Time to create page: 1.419 seconds
