Brother TC-211
- mblaszkiewicz
- Thank you received: 4
- Thank you received: 5335
you have to look at the error messages to determine
the cause.
Usually the hal line number and offending
statement are printed
- mblaszkiewicz
When I start Linux cnc and select the file I would like to use the config file I made is there. When I go and select it the ok button doors not light up. I don't get far enough to get an error message
One possibility worth checking...
Does the screen look something like this?
If so, you need to expand the "my-mill" or whatever folder to choose the config.
- mblaszkiewicz
One more question for the experts. Do the servos and motors have to be powered up on start up our can I start them after Linux is started
Rather than hope I really would suggest just buying an actual DC power supply. Something like: www.ebay.com/itm/New-24V-DC-6A-145W-Regu...&hash=item1e5feda61fI just got a new transformer for it and a few diodes to create an ac to dc bridge rectifier. I hope it works this time.
It is usual to have LinuxCNC turn on the servos and drives. Typically a field output would drive the main contactor. (an intermediate relay might be needed)One more question for the experts. Do the servos and motors have to be powered up on start up our can I start them after Linux is started
Absolutely, unless you know what you are doing I would not build a power supply
Also whats wrong with using the existing 24V from the brother machine?
One very basic note if you make your own PS from a transformer, you want about a
18VAC transformer (24VAC is way too high ) And you need a filter capacitor
- mblaszkiewicz
so I started linux with field power on, machine off and got the following error message
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.4
Machine configuration directory is '/home/mark/linuxcnc/configs/Brother_TC-211'
Machine configuration file is 'Brother_TC-211.ini'
INIFILE=/home/mark/linuxcnc/configs/Brother_TC-211/Brother_TC-211.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=2079
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko': -1 Invalid parameters
Brother_TC-211.hal:9: exit value: 1
Brother_TC-211.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
2079
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[10470.271179] I-pipe: Domain RTAI registered.
[10470.271208] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[10470.271214] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[10470.271231] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[10470.271237] PIPELINE layers:
[10470.271244] e22c1e20 9ac15d93 RTAI 200
[10470.271250] c085cb20 0 Linux 100
[10470.344549] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[10470.345101] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[10470.345115] RTAI[sched]: hard timer type/freq = APIC/6264188(Hz); default timing: periodic; linear timed lists.
[10470.345123] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1202740000 hz.
[10470.345130] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[10470.345412] RTAI[usi]: enabled.
[10470.579036] RTAI[math]: loaded.
[10470.811715] hm2: loading Mesa HostMot2 driver version 0.15
[10470.823629] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[10470.823730] hm2_pci 0000:01:09.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
[10470.823739] hm2_pci: discovered 5i25 at 0000:01:09.0
[10470.825840] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[10470.919692] hm2/hm2_5i25.0: Smart serial card 7i77.0.0 error = (28) Over Voltage
[10470.919711] hm2/hm2_5i25.0: Smart serial card 7i77.0.0 error = (15) Communication Not Ready
[10470.919723] hm2/hm2_5i25.0: Smart serial card 7i77.0.0 error = (13) Communication error
[10470.919734] hm2/hm2_5i25.0: Smart serial card 7i77.0.0 error = (8) Remote fault
[10470.919746] hm2/hm2_5i25.0: Smart serial card 7i77.0.0 error = (7) Too many errors
[10470.919757] hm2/hm2_5i25.0: Smart serial card 7i77.0.0 error = (6) Remote Fault
[10470.919770] hm2/hm2_5i25.0: failed to parse Module Descriptor 4
[10470.919790] hm2_5i25.0: board fails HM2 registration
[10470.919827] hm2_pci 0000:01:09.0: PCI INT A disabled
[10470.919866] hm2_pci: probe of 0000:01:09.0 failed with error -22
[10471.613777] hm2: unloading
[10471.756925] RTAI[math]: unloaded.
[10471.924199] SCHED releases registered named ALIEN RTGLBH
[10471.942167] RTAI[malloc]: unloaded.
[10472.040032] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[10472.050048] I-pipe: Domain RTAI unregistered.
[10472.050072] RTAI[hal]: unmounted.
Any thoughts ideas or advice helpful
I am hesitant to start the machine itself in case of a run away servo motor at this time. They have not been tuned yet.
[10470.919692] hm2/hm2_5i25.0: Smart serial card 7i77.0.0 error = (28) Over VoltageYou have too high of a field voltage ( greater than 32V)
This is likely to damage the 7I77 card or things you connect to it
- mblaszkiewicz
