Brother TC-211
- mblaszkiewicz
- Thank you received: 4
17 Aug 2014 03:14 - 17 Aug 2014 03:37 #49946
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
Just tried with the z axis. (it is diconected from the machine, so easier to work with)
all the axis have resolvers as you thought
I disconected the plug from cn8 and the motor will not turn at all now. No motion, no signals.
Next I will try at the plug end on the motor/ resolver while it is connected to the drive to see if I get some voltage.
Also had no control from linux.
Last edit: 17 Aug 2014 03:37 by mblaszkiewicz.
- Thank you received: 5335
17 Aug 2014 03:17 #49947
Replied by PCW on topic Brother TC-211
You cannot remove CN8 or the motor drive will not get any position signals from the motor (so measurements are of no use)
What I meant was looking an the signals from CN8 pins 9 and 10 when CN8 is connected (but the other end is not connected to the 7I77)
- mblaszkiewicz
17 Aug 2014 03:35 - 17 Aug 2014 03:38 #49948
by mblaszkiewicz
On the cn8 plug, there are no wires connected to pin 9 and 10 ??
When I checked I had voltage flucuations upto apx 3 volts.
Also no linux control for the axis.
Last edit: 17 Aug 2014 03:38 by mblaszkiewicz.
17 Aug 2014 03:50 #49949
Back in July I suggested connecting: (note this is encoder 0)
What _did_ you connect to the 7I77 encoder inputs?
DRIVE 7I77
ENCODER
CN8-10 A TB3-1
CN8-9 /A TB3-2
CN8-12 B TB3-4
CN8-11 /B TB3-5
CN8-17 Z TB3-7
CN8-13 /Z TB3-8
ANALOG VELOCITY COMMAND
CN8-1 AOUT TB5-4
CN8-2 GND TB5-3
- mblaszkiewicz
17 Aug 2014 04:08 #49950
by mblaszkiewicz
Also, just noticed, all my wiring is to cn9 on my machine, not cn8
Wow, I'll look into new connectors and re wire everything up, and get back to you.
- mblaszkiewicz
21 Aug 2014 07:40 #50125
by mblaszkiewicz
21 Aug 2014 09:04 #50126
Sure, as long as you use the correct ones
(this can be verified with a voltmeter as discussed previously)
- mblaszkiewicz
22 Aug 2014 04:49 #50162
by mblaszkiewicz
WOOOOO HOOOOOO
Got it working and reading movement on screen of Linux.
I have to work out the following error and tune servo's but I got it to read positions.
22 Aug 2014 04:53 #50163
Replied by andypugh on topic Brother TC-211
- mblaszkiewicz
22 Aug 2014 06:01 #50165
by mblaszkiewicz
Wired up wrong
Time to create page: 0.158 seconds
