Brother TC-211
12 years 1 month ago #50910 by andypugh
Replied by andypugh on topic Brother TC-211
mblaszkiewicz wrote: Is there anyway to right the z brake into the hal
Yes. I think that is what has been suggested.
somewhere you probably have a HAL signal linked to axis.2.amp-enable. Lets assume it is called z-enable
Then you just need a line something like
net zenable hm2_5i25.0.7i77.0.output-03
And then the digital output pin will follow the amp-enable signal in HAL. (note that I have guessed at he GPIO pin naming, it might not be correct)
It is possible that you might want a few mS delay between powering the amp and releasing the brake. Long enough that the motor is powered up and trying to control the axis before it starts to drop, short enough that the motor isn't trying to move a braked axis.
loadrt timedelay count=1 addf timedelay.0 servo-thread net zenable timedelay.0.in net zbrake timedelay.0.out setp timedelay.0.on-delay 0.1 setp timedelay.0.off-delay 0
Something like that.
12 years 1 month ago #50912 by cncbasher
Replied by cncbasher on topic Brother TC-211
Thats exactly what i was saying , but if you dont have 24v availlable then the brake will not work in any case
the only difference was i did it in hardware and not as code , one relay with 2 pairs of contacts one for the servo' and the other for the brake
12 years 1 month ago #50915 by andypugh
cncbasher wrote: using a 2 pole changeover relay , so they cant both be on at the same time , so on an energised relay the brake is powered ( across the normaly closed contacts ) on i pole , and the amplifier enable on the other pole but using the normaly open , then you only need to worry over 1 enable line and the brake will look after it's self
I don't think that axis brakes ever work like that. But I could be wrong.
Normally the brakes seem to be sprung "on" so that with no power the axis is locked, and it is actively unlocked when the motor is powered up and ready to use it.
12 years 1 month ago #50919 by cncbasher
Andy , by the picture it did not appear to be the sprung type , however it would appear by reading the OP does not have 24v Available , we need clarification
perhaps see if the op can turn the shaft at the coupler in the picture , would give us a start point i think
12 years 1 month ago #50932 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
I have 24 volts at my 7i77. On my servo the most I have on the control side is 10 volts. When the brake is energized it turns freely. When not energized it locks up.
12 years 1 month ago #50937 by cncbasher
ok thats good to know , so you need to supply power to the Brake to disable it , i would suggest that you check as i would think that the actual brake is operated by a relay and not directly
so wire the brake relay between 24v and a gpio pin on the 7i77. and use the delay code that Andy posted to delay release for a second or 2 to allow the servo amp to stabilise and hold
you may need to adjust the delays once you have it working
Time to create page: 0.226 seconds
