Brother TC-211
25 Aug 2014 07:12 #50247 by andypugh
Replied by andypugh on topic Brother TC-211
How do I swap the encoder scale in Hal
You just make the encoder scale a negative number.
Or a positive one if it is already negative.
25 Aug 2014 08:49 #50249 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
Where in the Hal file is it and what does the code look like please.
25 Aug 2014 10:04 #50251 by PCW
Replied by PCW on topic Brother TC-211
setp hm2_5i25.0.encoder.0N.scale something
25 Aug 2014 10:19 #50252 by mblaszkiewicz
I will try tomorrow and get back to you
26 Aug 2014 06:41 #50286 by mblaszkiewicz
OK back to errors in LinuxCNC again. When i start up I get
joint 1 on limit switch error. Any ideas ????
Thanks again to everyone here.
I also included the hal file.
File Name: Brother_TC...8-25.hal
File Size:10 KB
26 Aug 2014 07:05 #50287 by andypugh
Is joint 1 on the limit switch?
If not then what is the value of axis.1.pos-lim-sw-in and axis.1.neg-lim-sw-in ? If either of those is true then that explains it, and you will need to figure out why. It is possible that you need to invert the logic of the limit switch inputs.
If the HAL pins are showing "FALSE" then it may be a transient noise issue.
26 Aug 2014 07:58 #50290 by mblaszkiewicz
Yeah. I had the limit switches for the y axis backwards. All set. No run away on x anymore. I will take it. Tomorrow I bring home the indicators home with some gauge blocks and get tuning. Thanks for the info Andy.
29 Aug 2014 04:04 - 29 Aug 2014 04:09 #50433 by mblaszkiewicz
Ok can realy use some help. My boss just told me if al is ready the 1st job for machine will be in tuesday. So I have a copy of a mach3 tool changer sub. I was wondering if anyone here can translate it to linux for me. It is for the exact machine I have. Also any pin out call outs would be great in a descriptive file.
Also the sub will open in word pad. And is in romanian
File Name: tc-211toolchange.txt
File Size:15 KB
Last edit: 29 Aug 2014 04:09 by mblaszkiewicz.
04 Sep 2014 04:45 #50710 by mblaszkiewicz
Help please, I need to wire my z axis brake. I found the 2 lines (for 24v) but have no idea on how to wire it into my 7i77 card, and how to adjust the hal or ladder for it to work. Any help would be great, and thanks again to everyone here.
04 Sep 2014 05:10 #50716 by PCW
On just the electrical side of things, be careful, since the brake
cannot be driven directly by the 7I77, there must be a relay in
between
Time to create page: 1.594 seconds
