Brother TC-211
12 years 2 months ago #50240 by PCW
Replied by PCW on topic Brother TC-211
If the X axis DRO is correct (correct direction for X) you will need to change the analog output polarity
Not sure how this is done with pncconf, in hal its done changing the sign of
hm2_[HOSTMOT2](BOARD).0.7i77.0.1.analogoutN-scalemax
(where N is the channel)
12 years 2 months ago #50243 by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother TC-211
The dro is reading backwards, goes down in the pos dirrection, up in the neg dirrection.
12 years 2 months ago #50244 by PCW
In that case reversing either the encoder scale or swapping encoder leads is the solution
12 years 2 months ago #50245 by mblaszkiewicz
How do I swap the encoder scale in Hal
12 years 2 months ago #50247 by andypugh
Replied by andypugh on topic Brother TC-211
mblaszkiewicz wrote: How do I swap the encoder scale in Hal
You just make the encoder scale a negative number.
Or a positive one if it is already negative.
12 years 2 months ago #50249 by mblaszkiewicz
Where in the Hal file is it and what does the code look like please.
Time to create page: 0.347 seconds
