Starting another conversion Harrison L5a
23 Jun 2015 03:31 #60067 by mblaszkiewicz
Replied by mblaszkiewicz on topic Starting another conversion Harrison L5a
OK forgot to wire the enable on the c10 card. Now that it is hooked up getting 5v across pin 3 and the common/ground and pin1 common/ground. No movement yet
pin 2 is set to x step and pin 3 is direction
pin 2 wires to pul- on the driver
pin 3 wires to dir-
the common/ground is wired to pul+ and dir+
23 Jun 2015 03:37 #60069 by PCW
Stepconf only makes parallel port configs so if you connect to
your CPU's parallel port, it will likely work :-)
23 Jun 2015 03:53 #60070 by mblaszkiewicz
Is there anyway to configure it for the 5i25
23 Jun 2015 04:13 #60071 by mblaszkiewicz
Just tried the parallel port also. No movement .
23 Jun 2015 21:24 - 23 Jun 2015 21:28 #60091 by mblaszkiewicz
Anyone else have an ideas. It would be appreciated
Last edit: 23 Jun 2015 21:28 by mblaszkiewicz.
24 Jun 2015 00:43 #60095 by PCW
If you wish to use the C10 breakout with the 5I25, you must first choose an appropriate firmware to match the C10s pinout
You can do this by looking at the various .pin files in the 5i25.zip support image from Mesa (in configs/hostmot2/) and
checking to see which one is a close match to your C10 breakout. A g540x2 config may be close as should the probrfx2
Once you have chosen the firmware, you must re-flash the 5I25 with this firmware. This is done with the mesaflash utility
something like
sudo mesaflash --device 5i25 --write 5i25_g540x2.bit
to write the new firmware to flash
and
sudo mesaflash --device 5i25 --reload
to reload the FPGA with the new firmware
Then you should be able to use pncconf to get a close to correct set of hal and ini files by
choosing the 5i25 with the g540 firmware option (even if you are not using the G540 firmware,
the created hal and ini files should be close as all parallel port compatible pinouts are similar)
24 Jun 2015 01:47 #60096 by mblaszkiewicz
Ok since I wanted to use the cards for 2 machines that is not an option. Still no luck wroth the parallel port.
24 Jun 2015 01:49 #60097 by PCW
Why is it not an option?
24 Jun 2015 06:27 #60104 by mblaszkiewicz
I use the 5i25 card with my 7i76 card on my brother tc211. I don't want flash the card so it doesn't work with the other machine.
24 Jun 2015 07:42 #60106 by PCW
You can always flash it back to the old config
( the flash chip used has a lifetime of 10,000 writes so you are not likely to wear it out)
Time to create page: 0.581 seconds
