Starting another conversion Harrison L5a
30 Dec 2015 01:12 #67485 by andypugh
Replied by andypugh on topic Starting another conversion Harrison L5a
ipr is feed in inch per reveloution.
and the linux code is what I need to add to my hal
Ah, right, OK.
net spindle-position encoder.0.position motion.spindle-revs
net spindle-speed encoder.0.velocity motion.spindle-speed-in
net spindle-index motion.spindle-index-enable encoder.0.index-enable
(but check the motion pin name in the manual page, I am not 100% sure about the combination of . and - characters
The following user(s) said Thank You: mblaszkiewicz
30 Dec 2015 02:11 #67488 by mblaszkiewicz
Replied by mblaszkiewicz on topic Starting another conversion Harrison L5a
Will that also take care of threading
30 Dec 2015 11:54 #67503 by andypugh
Yes. Threading relies on position and index.
30 Dec 2015 22:17 #67551 by mblaszkiewicz
I ran into a little problem
./custom.hal:4: pin 'encoder.0.velocity' was already linked to signal 'spindle-velocity-feedback-rps'
anyway to fix it up ???
30 Dec 2015 22:55 #67554 by andypugh
That probably means that it doesn't need fixing, it is probably already linked in the main HAL file.
Did you look?
30 Dec 2015 23:11 #67555 by mblaszkiewicz
net spindle-velocity-feedback-rps encoder.0.velocity => motion.spindle-speed-in
yes it is the main hal.
do i need to change one or delete one ??
30 Dec 2015 23:12 - 30 Dec 2015 23:13 #67556 by andypugh
Neither. leave that one as it is, it's fine.
You can choose signal names freely, they have no special meaning. Think of them as a wire colour.
Last edit: 30 Dec 2015 23:13 by andypugh.
30 Dec 2015 23:13 #67557 by mblaszkiewicz
do I remove the one I added in the custom hal
30 Dec 2015 23:14 #67558 by andypugh
Yes, remove the one in the custom HAL.
And see if the other motion.spindle... pins are already netted too, they probably are.
30 Dec 2015 23:19 #67559 by mblaszkiewicz
yes they all are. How do I work around it
Time to create page: 1.832 seconds
