Starting another conversion Harrison L5a
- mblaszkiewicz
- Thank you received: 4
03 Dec 2015 00:44 - 03 Dec 2015 00:44 #66248
by mblaszkiewicz
Replied by mblaszkiewicz on topic Starting another conversion Harrison L5a
Well got everything running.
now waiting for new ball screws.
I have over .030 backlash on the acme screw so time to change it out.
They should be here on the 8th, so should have them all remachined and installed on the 10th or the 11th.
Wish me luck
Wish me luck
Last edit: 03 Dec 2015 00:44 by mblaszkiewicz.
- mblaszkiewicz
28 Dec 2015 17:36 #67403
by mblaszkiewicz
New update
I have the ball screw in and my backlash is about .002 so much better. I will add in a backlash for it.
now the problem.
I wired in an encoder on the spindle. I have not been able to read any output to the pins in hal scope at all.
I am hoping someone will see what I did wrong..
I encuded my hal and ini files and some pics.
now the problem.
- mblaszkiewicz
28 Dec 2015 17:55 #67404
by mblaszkiewicz
- Thank you received: 1476
28 Dec 2015 18:59 #67405
Replied by Todd Zuercher on topic Starting another conversion Harrison L5a
The obvious thing I see is in your hal file you have A B and Z connected to pins 12, 13, and 15, but here at the card you have it wired 10, 11, &12.
The following user(s) said Thank You: mblaszkiewicz
- mblaszkiewicz
28 Dec 2015 19:25 #67406
by mblaszkiewicz
opps will try a quick recheck on that and change it around.
- mblaszkiewicz
28 Dec 2015 20:52 #67409
by mblaszkiewicz
ok reset the pins. I'm getting speed readings but not right.
I reset the encoder to 100 in the hal file
now I have a speed reading but it is way off
at 42 rpm it displays apx. 180
at 960 it is 3800 apx.
also no reading from the index on the encoder.
28 Dec 2015 21:30 #67412
What is your encoders counts/rev?
If you have a 100 line encoder connected 1:1 with your spindle, it was probably right when you had it at 400 before.
Since your reading the encoder with the parallel port you also have to remember that you won't be able to read the encoder faster than you can read the parallel port (which is read at your base thread speed).
- mblaszkiewicz
28 Dec 2015 21:33 #67413
by mblaszkiewicz
ok will try the 400.
any idea on why the index does not read ????
28 Dec 2015 21:37 #67414
How are you looking for it?
- mblaszkiewicz
28 Dec 2015 21:47 #67415
by mblaszkiewicz
ok with the encoder set to 400 here are my results
gear speed displayed
42 48
276 306
60 68
392 431
96 105
614 672
150 165
960 1006
my machine has 4 speeds hi and low for each.
I am wondering if the encoder might ne right and the gear speed from the machine might be off.
42 48
276 306
60 68
392 431
96 105
614 672
150 165
960 1006
Time to create page: 0.707 seconds
