- Thank you received: 5334
Yet it always, always ends up something was changed.The last time the machine was running (the video is a few pages back), I only updated the firmware of the 7I97, from Debian10 to Debian13, and the LinuxCNC software. There were no changes to the wiring, hardware, or the HAL/INI files.
What error? We can not help you if you keep holding important information from us.As soon as the limit switch moves to the cam, the axis stops, and after a few seconds, an error message appears.
They can NOT be the same, Z axis is almost always moving in negative space, not in positive as X and Y.The settings for all three axes are the same; you can see them in my latest .ini file.
