Hurco BMC 30 AP
5 months 3 weeks ago - 5 months 3 weeks ago #346262 by 5_Zylinder
Replied by 5_Zylinder on topic Hurco BMC 30 AP
I traced the path on the circuit board a bit and came across the following two components: 75174N-H and SN75175N.
Last edit: 5 months 3 weeks ago by 5_Zylinder.
5 months 3 weeks ago #346263 by PCW
Replied by PCW on topic Hurco BMC 30 AP
That makes sense, the 75175 is likely the differential encoder input circuit
and the 75174 is used for an emulated encoder output or some such...
5 months 3 weeks ago #346264 by 5_Zylinder
I'll swap them both and see if that solves the problem. Otherwise, it'll be difficult.
5 months 2 weeks ago #346378 by 5_Zylinder
A quick update from my end: I replaced the two components on the encoder board, but unfortunately, the encoder signal is still not being processed. Without a schematic, I really don't know where else to look.
I'm still waiting for the optocoupler so I can get the second board back up and running.
5 months 1 week ago - 5 months 1 week ago #346618 by 5_Zylinder
I replaced the optocoupler, and the output is working again.I attempted to set up the tool changer. Unfortunately, I keep receiving the following error messages when starting LinuxCNC. Attached is my .ini file.
Last edit: 5 months 1 week ago by 5_Zylinder.
5 months 1 week ago #346640 by tommylight
Replied by tommylight on topic Hurco BMC 30 AP
Those seem like two separate issues, one remap is not doing OK and the other complaining about gcode, are you running the default "Linux CNC" gcode?
Time to create page: 0.438 seconds
