biesse rover 316 retrofit
4 years 9 months ago - 4 years 9 months ago #230506 by Masiwood123
Hello My name is Vladimir
After reading many interesting and useful posts I would like to present my future project.
Machine is biesse rover 316, 1991y, with old rt480...in good phisical condition but not jogging etc.Even if it works, that brain is hard to use in these times, so I decided to avoid mach3 this time and enter the linuxcnc world. From this point it seems quite complicated, but since I'm not very inexperienced in electronics, I hope to understand and revive the machine...some first steps are inserting the computer, enabling the estop line and ready voltage for the cards I ordered. these are 7i92m, 7i77,7i74 and 7i66 / 24...here is that i did for now..   thanks in advance for the help and suggestions
Last edit: 4 years 9 months ago by Masiwood123.
4 years 9 months ago #230952 by tommylight
From the choice of cards i assume you have read the "servo tuning detailed howto", or if you did not, find it and read it, it has info on wiring and testing and tuning analog servo systems.
The following user(s) said Thank You: Masiwood123
4 years 9 months ago - 4 years 9 months ago #230956 by Masiwood123
  Thanks a lot. (I read superficially, so I'll be more detailed when it comes to that) I received the cards yesterday, today the first step is to install them and set the power jumpers, and connect them to the PC. I will focus primarily on putting 7i92 and 7i77, 7i74 as well as 7i66 / 24 into function for later. Around the servo tuning, by the way, I have a scheme with a lieadscrew step, and maximum factory speeds
at 10v. my first question is do i need to do a firmware update since i have a circuit of those 4 cards 7i92,7i77,7i74 and 7i66 / 24? thanks in advance
4 years 9 months ago #230958 by tommylight
Most probably the firmware would need to be changed, but it is included in the download from Mesa web site.
That page with info is very good, should make the tuning very easy.
If you have the Mesa 7i92M (notice the M ) just plug it into Mesa 7i77, and use a parallel cable for 7i74.
I have no clue what 7i66 is. :(
4 years 9 months ago #230959 by Masiwood123
well then I'm on the right track, that about connecting the cards it's pretty clear to me, about the update command I'll find somewhere on the forum ... as for 7i66 / 24 as far as I'm concerned I took it to directly give the solenoid outputs as far as the drill is concerned because only it has up to 2.5A direct output. I'm coming up with a new upgrade..thanks a lot for the answers.
4 years 9 months ago #230967 by tommylight
Pozdrav Vladimire,
Just had a look at 7i66, yeah i guess i did not spend enough time browsing the Mesa website at the time when i ordered my stuff several years back, that card would have saved me two days of adding and wiring relays!
On that topic, if all you want to use is 7i92, 7i77 and 7i66 with no other cards, no need for 7i74 as 7i77 has a free SSerial port on it that the 7i66 can be wired to directly. So that would mean no need to flash 7i92 if it already has firmware for 7i77, easy to check with:
mesaflash --device 7i92 --addr 10.10.10.10 --redhmid
That is if you set the jumper for the EEPROM address on the 7i92.
Time to create page: 0.101 seconds
