biesse rover 316 retrofit
4 years 9 months ago - 4 years 9 months ago #231066 by Masiwood123
I managed to delete wicd, I managed to install network manager, I managed to update the firmware on 7i92 (when I worked w4-w12 were in setup mode), I managed to reload mesaflash, the pc has a connection to 7i92 ping 10.10.10.10 works , w1 is in the left hand, on all 5 pins there is 24v and on the last gnd. BUT .. the situation is still the same, people fly to the moon and I can't get into the configuration :)
Last edit: 4 years 9 months ago by Masiwood123.
4 years 9 months ago #231068 by Clive S
Replied by Clive S on topic biesse rover 316 retrofit
The error shown is on line 26 in the hal file
setp [HMOT](CARD0).dpll.01.timer-us -50
setp [HMOT](CARD0).stepgen.timer-number 1
I don't see the ref  [HMOT](CARD0) in the ini file.
   So try just try and comment it out with a #    like #setp [HMOT](CARD0).stepgen.timer-number 1
To see if it loads
4 years 9 months ago #231071 by Masiwood123
ok thanks
this ini and hal was later with that config. i will attach new ini and hal with last config after i update firmware and install network manager , and also follow and use instructions for network settings by tommylight
4 years 9 months ago #231078 by Masiwood123
Here is new files ini and hal, nothing better:(
File Name: new.hal
File Size:10.43 KB
File Name: new.ini
File Size:3.39 KB
4 years 9 months ago - 4 years 9 months ago #231080 by PCW
Replied by PCW on topic biesse rover 316 retrofit
Can you start LinuxCNC from the command line and copy-paste
any errors you get to the forum?
It's pretty hard to guess what "nothing better" means
Last edit: 4 years 9 months ago by PCW.
The following user(s) said Thank You: Masiwood123
4 years 9 months ago #231081 by Masiwood123
the hardware is 7i92 + 7i77, when i age the linux cnc configuration it throws out the error i pinned in the pictures and doesn't let me go, when i say nothing better i think nothing has changed in the sense that i have solved the access problem. and I did everything I know. I'm slowly thinking about selling cards and switching to mach3, I'm persistent and optimistic but this is too much :)
