biesse rover 316 retrofit
4 years 9 months ago #231035 by Masiwood123
4 years 9 months ago - 4 years 9 months ago #231038 by Masiwood123
File Name: proba.hal
File Size:10.43 KB
File Name: proba.ini
File Size:3.46 KB
after i update firmware to 7i92, there is new bug report. also i attach ini and hal.
Last edit: 4 years 9 months ago by Masiwood123.
4 years 9 months ago #231041 by tommylight
Yeah, that will need a flash with the firmware for 7i77, it seems it has stepgen firmware.
So
sudo mesaflash --device 7i92 --addr 10.10.10.10 --write 7i92_7i77_7i74D.bit
then
sudo mesaflash --device 7i92 --addr 10.10.10.10 --reload
Download the support files from www.mesanet.com , unzip, find the file mentioned above with the .bit extension and copy it to your home folder, then use the above commands.
4 years 9 months ago #231043 by Masiwood123
Yes Tom i already did it but i didn’t reload.. now i am on the line to install pc again and will try again. Thank you very much!
4 years 9 months ago #231044 by tommylight
4 years 9 months ago #231045 by Masiwood123
i think yes but can’t be sure.. for half hour i will try again waiting now to finish install pc. btw its the same network not access to “edit connection” and as i see i don’t have permission to install network manager again.. we will see what should happen later when attach pc.
Time to create page: 0.135 seconds
