biesse rover 316 retrofit
4 years 9 months ago #230972 by Masiwood123
Pozdrav Tom
yes that is always something we figured out later but whatever also with everything helps here is good for everyone… i am now on the way to connect power and to try direct from 7i77 to link 7i66..and will present next step ubgrade. thank you for support
4 years 9 months ago #231001 by Masiwood123
  After a few hours I have some results that are not very satisfactory but I go further. The main problem of the network is that "edit connection" does not have any screen, so I do not have access to input for ip at all. I had to reinstall Linux and manually enter a static ip in the input field. then I finally got a connection with 7i92 and 7i77 and made a pncconf configuration based on the factory parameters of the machine. mesaflash reads the card from the terminal and that's ok. the configuration won't start it throws out an error but I think it's because I haven't brought power to vfield yet and I haven't connected the encoders so I'll do it tomorrow. reading the posts I found a way to install nm doesn't work for me? is there another way I can access the network card or some other way to install a normal network manager?
4 years 9 months ago #231004 by tommylight
sudo apt-get update
then try to install.
Mesa cards will work with just power attached and so will LinuxCNC, 5V and VField must be present.
4 years 9 months ago #231030 by Masiwood123
  Everything is the same .. all night and now I'm trying to access linuxcnc, 7i92 recognizes, mesaflash --device 7i92 --addr 10.10.10.10 --redhmid works, I brought power to vfield from the machine (the manual says that switches are not used but I don't know how else to bring 24v to vfield) and like 5v when I make the configuration and try to start the machine, throw out the error :(
4 years 9 months ago #231033 by PCW
Replied by PCW on topic biesse rover 316 retrofit
1.Do you have 7I77 firmware installed in the 7I92
2. What error message do you get?
The following user(s) said Thank You: Masiwood123
4 years 9 months ago #231034 by Masiwood123
just from here i didn’t install any firmware update. i did update and upgrade.. i enter ip manually on linuxcnc install because right click on editing connection doesn’t work. pc is dell980 with tplink adaprer for wireless and it works.
Time to create page: 0.211 seconds
